Guy Mancuso
Administrator, Instructor
Yes it is the shade and a cooler color temp but I did use color editor on the horizontal image on the blue sky to darken slightly than i copied my adjustments over to my vertical stack and than it brought the snow in a little cooler than it should be. Going to fix that now by desaturating the snow slightly. Here I would now drop my smoothness down in color editor so I only affect the snow. Color editor is a amazing tool in C1 but must be done with care as well or you will over do it. Good trick is take a sample and make very slight adjustments than repeat it over again with another sample in the same area. Go in small steps is the real trick.
