Results 1 to 5 of 5
Thread: Zeiss 50mm/2 ZE Makro
    760
    Did i miss a thread or has anyone used this lens with their canon? I have heard glowing things but wondered if there is any consensus here. M
    Tiburon, CA
    108
    Re: Zeiss 50mm/2 ZE Makro
    I use the ZF version. I assume they are the same optically.
    Best 50mm lens I have ever used.
    screenwash
    What about the nifty fifty? Cheap but awesome optics?
    Troubled Bison
    I too am a bit curious about this. I'm interested in going prime but not 100% sure what direction I want to go in.
    Mar 2011
    Washington State
    67
    I did a lot of research on "normal" lenses before purchasing the ZE f/2 Makro, and I'm extremely pleased with the build and with the photos that this lens helps me to produce. However, I can't compare my experience with it to any other 50mm lens -- this is the only 50mm lens I've owned in recent decades. I also use the Zeiss ZE 21mm lens, and I'm equally enthusiastic about it for wide-angle use.
    Stephen Penland
    www.stephenpenland.com
