Results 1 to 9 of 9
Thread: Leica 2/90 R or C/Y 85 f1.4 ?
    lukafoto
    For use on Canon EOS 5D2 for stills and video work. Any idea which is the better of the two for image quality, handling etc?
    Do quite a bit of air to air photography in confined cockpit spaces!
    Kind regards
    Feb 2011
    Italy
    34
    Re: Leica 2/90 R or C/Y 85 f1.4 ?
    Never used these lens for video shooting but for photos purpose only I prefer the 90/2 R. Perfect lens!!!
    498
    8
    Not sure. I've never used the Contax lens. There are two versions of the Leica lens, APO and the older version. The older version is very soft with a fair bit of spherical aberration at f2 and is "sharp enough" by f5.6 giving the lens several different looks. The APO version is sharp from f2. I have never used either for video, but I imagine they would be fine particularly up close where you have a lot of focus throw. The focus throw tightens significantly from about 40' to infinity and focusing in that range is a little touchier. The 90/2 is very compact and light, about the size and weight of a Canon 85/1.8, but with typical Leica build quality.
    Subscriber Member Jonathon Delacour's Avatar
    Sydney, Australia
    454
    7
    Quote Originally Posted by Bill_Green View Post
    Actually, it's the Elmarit-R 90/2.8 lens that is very compact and light and about the size and weight of the Canon 85/1.8, whereas the Summicron-R lenses are about 25% heavier.
    I have (and use) the Elmarit-R 90/2.8, the Summilux-R 80/1.4, and the Contax C/Y 85/1.4. The APO-Summicron-R 90/2.0 is evidently a stellar lens but usually sells for well over USD3000.
    Two other lenses you might like to consider are the Summilux-R 80/1.4 and the Contax C/Y 100/2.0. Although expensive the 80/1.4 is like having two lenses in one: the dreamy Mandler look wide open yet very sharp stopped down. If I had to choose between the 80-90mm lenses I own, as much as I like the Zeiss 85/1.4, I'd keep the Summilux-R 80/1.4. It's heavy though. The 100/2 has a great reputation and can probably be had for about half the price of the 80/1.4.
    Summilux-R 80/1.4: 700 g / 24.7 oz
    Contax C/Y Planar 85/1.4: 595 g / 21 oz
    Summicron-R 90/2.0: 560 g / 19.7 oz
    APO-Summicron-R 90/2.0: 520 g / 18.3 oz
    Elmarit-R 90/2.8: 450 g / 15.8 oz
    Canon EF 85/1.8: 425 g / 14.5 oz
    Contax C/Y Planar 100/2: 670 g / 23.6 oz
    Nov 2009
    NYC
    276
    Another vote in favour of the Summilux-R 80/1.4 for the same reason that Jonathon Delacour mentions. This lens is amazing, but I still use the 85L quite a lot because of the AF.
    I had the Leica Elmarit-R 90 and just didn't like it enough to put it in the bag. It's a great lens but just not for me.
    Jun 2011
    31
    The 85/1.4 C/Y is 'dreamy' on film wide open - unfortunately this looks a bit 'fuzzy' on digital. Sharpens up by f2, really crisp at f4
    90/2 Summicron
    (old tests on a 5d)
    The 90/2 APO is really sharp. Corners adequate at f2, sharp a stop in. Great color/contrast. Front bokeh can be a little harsh, but rear bokeh is fine. One thing I like about it is no longitudinal chromatic aberration, which is really obvious on the 85L/1.2. Nice compact lens, compared to the 85L and 85c/y.
    Summicron:
    Zeiss: Softer OOF transitions
    In terms of handling, the EOS/Leica adapters seem much more secure, solid and stable than EOS/CY adapters (might have improved over the last few years, but I've got lots of 'wobbly' adapters, and the 85c/y is fairly heavy, and my adapters seem a little 'sloppy' compared to R).
    Feb 2008
    Uppsala, Sweden
    187
    I chose the 90 Summicron-R (non-APO) much because of its ability to focus as close as 0.7m. Only Leicas 90mm lenses do this, all others are at 0.85-0.9m (85-90mm lenses). The MFD is really useable in some situations. The 90 cron is indeed a bit soft at wider apertures, which is really nice in some situations, depending on the look that you want.
    If you are going to use the lens a lot it might make sense to swap mounts (see leitax.com) instead of testing adapters.
    Nov 2009
    NYC
    276
    Quote Originally Posted by pgmj View Post
    Leitax is the mount that I chose as well, as for the Leica R lenses they are all wonderful! You just can't go wrong!
    Aug 2008
    Ontario, Canada
    96
    You should also consider the Contax 2.8/85 Sonnar. That lens has it all, sharpness, bokeh, light weight. It may be a little slower than the other lenses you've considered, but it's incredibly sharp edge-to-edge, even wide open.
    The MTF curves for this lens aren't curves at all, they're essentially straight horizontal lines. You can still download them from here.
