Results 1 to 8 of 8
Thread: 40mm EF f/2.8 pancake compatibility question
    Sep 2011
    Devon, UK
    286
    Does anyone on the forum have experience of using the 40mm Canon pancake lens on a 5D Mk1?
    I seem to recall reading something about a 5D Mk2 (or later) being required for FULL functionality with regard to using manual focus with this lens. However, I'm not at all certain about this 'recollection', so I thought I'd ask on here for any first-hand user experience. TIA.
    Sep 2011
    Devon, UK
    286
    Re: 40mm EF f/2.8 pancake compatibility question
    I've had this question answered outside the forum.
    I can't find any way of deleting this thread, so perhaps a mod would delete it.
    Apr 2010
    Somerset - UK
    92
    and the answer was?
    Sep 2011
    Devon, UK
    286
    The answer was: Yes, it works fine!
    I must have been mistaken regarding the article which (I thought) I'd read...
    May 2009
    447
    You can't update the firmware of the 40 STM yourself using a 5D - you need a relatively recent body (T4i, 5DIII, 1D X or later) to be able to do that. This was an issue because early-production 40's needed a firmware update to fix a little bug:
    ___________________
    Product Advisories
    Thank you for using Canon products.
    Canon has released a firmware update for the EF40mm f/2.8 STM Interchangeable Lens for Canon Digital SLR Camera.
    Affected Product
    EF40mm f/2.8 STM
    Details
    Firmware Version 1.2.0 addresses the following phenomenon.
    1. If pressure is applied to the lens barrel while the lens is mounted to the camera (pressure can be applied even while attaching the lens cap while carrying the camera with the lens attached in a bag), the autofocusing function of the lens may stop working.
    __________________
    I had to send my 40 back to Canon for the update because I didn't have a late-model body at the time.
    But other than that, the 40 works fine on any EOS body back to the very beginning.
    Sep 2011
    Devon, UK
    286
    Interesting - thanks for posting. I hadn't heard or read anything about this particular problem.
    How long ago did you purchase your 40mm? Presumably, a lens purchased now would (or should ) have the later firmware. Do you happen to know whether there is a method to check which firmware is installed on the lens, if you have an earlier camera? TIA.
    Sep 2011
    Devon, UK
    286
    I found the answer to my own question... here's an extract from the Canon UK website:-
    The lenses with the following serial numbers are equipped with Firmware Version 1.1.0:
    The third digit in the serial number is either 0, 1, or 2 (xx0xxxxxxx、xx1xxxxxxx、xx2xxxxxxx).
    Lenses with serial numbers other than those listed above are equipped with Firmware Version 1.2.0
    Sep 2011
    Devon, UK
    286
    A quick follow-up to this thread... I purchased the EF 40mm f/2.8, and am pleased with it.
    Its IQ is good; not absolutely great - but certainly very acceptable, especially for the price. I find that I prefer the 40mm focal length, in use, to either a 35mm or a 50mm. It's interesting that a small difference in focal length can make such a difference. The lens is also very small and light.
    In value-for-money terms, for me, it's a definite winner. The EF 40mm has been practically welded to my 5D in recent weeks, and that camera has seen more use as a consequence.
