Results 1 to 4 of 4
Thread: Nikon PC-E on an eos body
    Irvine, CA
    230
    24
    Hi-
    I have a Nikon 45mm f2.8D PC-E lens that I would like to use on an EOS camera mount. I've tried the Novoflex EOS/NIK NT N adapter which works well except the aperture. This adapter does work with G lenses but not the PC-E which has an aperature ring.
    Any help would be appreciated.
    jim
    Little Rock AR
    1,925
    3
    Re: Nikon PC-E on an eos body
    It's my understanding the PC-E will not work on Canon as the aperture connection is electronic. Even though there is a manual aperture ring the controls are all electronic. Other G lenses should work with the novoflex adapter.
    Paul
    Feb 2011
    New York
    79
    Give SK Grimes a call. They might be able to do a conversion.
    Irvine, CA
    230
    24
    Hi-
    Thanks for the info. I ended up buying an UG N90 camera from KEH which I used to set the aperture at f8. Once set it stays.
    When the new Canon 45 TSE comes out (if ever) I'll replace the Nikon.
    jim
