Results 1 to 4 of 4
Thread: Help/Advice
    Senior Member ecliffordsmith's Avatar
    Mar 2008
    Antwerpen
    467
    Help/Advice
    Hi All,
    A friend of mine has a canon 400D (rebel xt ???) and it has just packed up. He is off on holiday tomorrow so I am going to try and get it fixed while he is away.
    He had just finished uploading files from his camera to his PC and thinks he may have switched the camera off a little to soon. The transfer was complete as the files are ok but now the camera will not turn on again. He has tried different cards and a fully charged battery.
    Are there any other things to check before sending the camera in? Is it best to contact Canon directly or send it in via the dealer?
    Many thanks for any advice you can provide!
    1,513
    Re: Help/Advice
    Ed,
    Though I have never experienced this problem, it sounds like one of the electronic glitches confused the "brain". Advice that others have used somewhat successfully for other cameras, including the M8, it to remove the battery overnight (or a good 8+ hours), then insert a freshly charged battery and a card you know was clean or formatted before. That could be all that is needed to bring it back to life. If that fails, it may be worth a call to Canon to see what they may suggest. If it does have to go to them for repairs, turnaround is generally quite fast, but maybe not fast enough for you friend to take with him.
    LJ
    California/Thailand
    1,206
    Re: Help/Advice
    I agree with LJ, and suggest removing the battery for 8+ hours, replace with a fully charged one, etc., as he posted. This has resolved similar hiccups for others.
    If it goes to Canon, the turn-around (in the U.S.) can vary from a couple of days to several days (like a week or two) depending on parts required, etc. I have read that Canon service in the U.S. is faster than Canon in Europe, but that may have changed now. I have had very good service from Canon Repair in Irvine, California, and Bangkok, Thailand.
    Mar 2008
    Antwerpen
    467
    Re: Help/Advice
    LJ/Dayle,
    Thank you both very much for your advice, it is very much appreciated. It has been a public holiday here today but in the morning I intend to ask a local shop what they suggest.
    Once again, thanks for your advice!
