Results 1 to 7 of 7
Thread: Lacie 324 24" LCD Monitor $600 OBO
    Oct 2009
    341
    http://www.lacie.com/products/product.htm?pid=11034
    Selling my Lacie 324 monitor with hood because I am buying a 27" iMac. I paid 999 for this from B&H about a year ago. Awesome monitor with HDMI Inputs great for photo editing.
    Looking to get 600 or best offer. Will ship fedex ground, buyer pays shipping and paypal if you go that route.
    Specs from Lacie's website:
    Item Number : 130778
    Diagonal : 24 in. / 61 cm
    Display Area : 20.41 x 12.75 in. / 518.4 x 324 mm (HxV)
    Apsect Ratio : 16:10
    Maximum Resolution : 1920 x 1200
    Dot Pitch : .01 in. / .27 mm
    Color : 16.7 million (true 8-bit)
    Video Inputs : HDMI x 2; 24 Pins DVDI-D x 1; 15 Pins D-Sub x 1
    Audio Outputs : Headphone / Speaker mini-jack
    Color Gamut : 92% of NTSC / 95% of Adobe RGB / 99.7% of ISO Coated
    Gamma Correction : 10-bit
    Luminance : 400 cd/m2 (Center, typ.)
    Power : AC 100~240V / 47~63Hz
    Contrast Ratio : 1000:1 (typ.)
    Response Time : 6ms (G-G avg.)
    Viewing Angles : R: 89, L: 89, U: 89, D: 89 (CR >= 10, typ.)
    Certification : CB, FCC, CE, CSA, Canada DOC, EPA, ISO13406-2, GOST, PSB
    USB Port : 1 up, 3 down
    USB Output : A-type Connector x 3
    Weight : Approx. 23.81 lbs. / 10.8 kg
    Gross Weight: Approx. 29.54 lbs. / 13.4 kg
    Dimensions (WxHxD) : 22.28 x 16.45-19.21 x 8.97 in. / 565.9 x 418-488 x 228 mm
    Compatibility : Mac & PC
    RoHS Compliant : Yes
    Power Consumption : 140W (max.)
    Comments : *For full automatic performance of hardware calibration with blue eye pro, a graphics board supporting DDC CI communication is required.
    144
    Re: Lacie 324 24" LCD Monitor $600 OBO
    what is your location??
    Oct 2009
    341
    Omaha, NE
    Oct 2009
    341
    bump
    Oct 2009
    341
    bump
    Oct 2009
    341
    bump
    Oct 2009
    341
    No takers? I don't want to have to put it on the 'bay
