Elinchrom Ranger RX Speed AS Generator ‘To-Go’ Kit
John Kraus
1100 Total Watt/Seconds battery operated, includes:
- #10267 RX Speed AS Power Pack
- Freelight "S" Flash Head
- Varistar Umbrella Kit
- Wide Angle Reflector, Grid Reflector
-Charger, Extra Battery
- Sync Cord, Strap, Hard Case
Very light use, perhaps 2 dozen times. (B&H price $2225)
Comes with additional 3rd Battery! ($242.95 value)
Selling for $1835
Similar to Pro Photo 7B, I believe better. Weatherproof, 7 stop range, short duration flash, quick recycle. Built like a tank.
The "RX" signifies the ability to be fired by a remote control handset, or computer. The power range selection is 7 f-stops. Lower the power to 8.5 w/s, and switch to slow recycleand up to 3800 exposures can be made before recharging is needed.
Included in this kit is the Varistar 33" Umbrella-(see below).
Elinchrom Ranger has flash durations as short as 1/4310 sec. (with 2 "A" heads attached), ideal for sports, fashion, and theatre photography. Controls on the pack permit changing the output in 0.1 stop increments in an easy-to-read digital display.
This is a 1 head, Speed AS kit which includes a Freelite "S" flash head, and a Speed AS power pack, which allows asymmetrical power distribution of the power to the two head outlets.
• Varistar Kit
The Varistar umbrella and reflector is a multi-purpose light source...wide angle, even and soft. The kit includes the 26164 wide-angle reflector and 26381 umbrella/softbox. The 41" Varistar is ideal for industrial, portrait and groups. It's easy to assemble and lightweight. It is suited for portraits and shots of 1 - 2 people.
• Compact Design
Easily transportable, fits easily into many location cases.
• Weatherproof
Special sealed controls and capped flashhead connectors, sealed bottom, battery drawer access from side of unit.
• 7 F-Stop Range
8.5 - 1100 w/s, digitally controlled in 0.1 stop increments.
• Fast Recycle Time
2.9 seconds to full power for approximately 140 flashes.
• Recycle Indication
2 LED's and an Audible Switchable Beep signify flash is ready to fire.
• Fast Recharging
The multi-voltage charger can charge a battery in 3 hours to full power, inside the unit, or externally.
• Conserves Battery Power
Automatically switches off 5 minutes after the last operation.
LED's indicate remaining battery power.
• Built in Slave
The photo cell is adapted to trigger in bright ambient light.
• Auto Dump
Allows access to lower power selections without the need to manually dump a higher power first.
• Memory
Retains all previous settings since last use.
• Compatible
An adapter cable (11095) is available to use existing Elinchrom heads with the Ranger pack.
SF Bay Area sale preferred, US Mainland only.
