Hi Brad,
I have a mid-2009 15" Unibody MBPro, 2.93 GHz model with the
Expresscard slot. I'm wondering if your battery will work on this laptop. I've pasted the battery info below but can't seem to find a model number. Can you tell from this Battery Info that I've pulled from the system profiler if yours will work?
Thanks,
Lawrence (
[email protected])
Battery Information:
Model Information:
Serial Number: 6N906072Z2VLA
Manufacturer: SMP
Device name: bq20z951
Pack Lot Code: 0000
PCB Lot Code: 0000
Firmware Version: 002a
Hardware Revision: 000a
Cell Revision: 0100
Charge Information:
Charge remaining (mAh): 4134
Fully charged: Yes
Charging: No
Full charge capacity (mAh): 4296
Health Information:
Cycle count: 28
Condition: Normal
Battery Installed: Yes
Amperage (mA): 0
Voltage (mV): 12392
System Power Settings:
AC Power:
System Sleep Timer (Minutes): 180
Disk Sleep Timer (Minutes): 10
Display Sleep Timer (Minutes): 60
Automatic Restart On Power Loss: No
Wake On AC Change: No
Wake On Clamshell Open: Yes
Wake On LAN: No
Current Power Source: Yes
Display Sleep Uses Dim: Yes
GPUSwitch: 2
Battery Power:
System Sleep Timer (Minutes): 17
Display Sleep Timer (Minutes): 16
GPUSwitch: 2
Reduce Brightness: Yes
Hardware Configuration:
UPS Installed: No
AC Charger Information:
Connected: Yes
Wattage (W): 85
Revision: 0x0000
Family: 0x00ba
Serial Number: 0x00933c63
Charging: No
