There are controls in CaptureOne to compensate for Lens Cast , but the amount of it on the P30 will be more significant and therefore it is not recommended for use on a cameras with movements.
If you want to use movements use the p20,p21,p25 or p45.
Here is an excerpt right from the Phase One knowledge-base:
" The CCD used on the P 30 makes use of an extremely small microlens for each pixel. The microlens design increases the performance of the CCD by focusing more light into the center of the pixel well where the CCD is most efficient. The microlens design improves the sensor efficiencies for light reaching the sensor at extreme angles. At increasing angles of incident light, the microlens will be less and less efficient until no light at all is focused into the pixel wells.
For normal use on a medium format camera, the angle of incident light does not exceed the limitation even though you make use of wide angle lenses. If P30 is used on the large format cameras using tilts, swings, and shifts you may exceed the angle of light. In these cases the first thing you will observe is a significant light fall-off on the edges of the image. "
Lance Schad
Capture Integration - Miami/Atlanta
305-394-3196 cell | 305-534-5702 office
Capture Integration
My Blog
[email protected]
