FS: Gitzo G2380 Fluid Tripod Head
bradhusick
Original owner selling like-new Gitzo G2380 fluid tripod head shipped in CONUS for $225. Cost $300 new a few months ago.
The G2380 fluid head is specifically designed for the new range of lightweight and compact camcorders and DSLRs used by advanced enthusiasts and professionals. Some specific features also make this head the ideal tool for photographers and bird watchers using long focal length lenses. First, pan and tilt locks and separate friction controls are positioned on the same side for ergonomic, fast and precise action. Second, the pan lock is based on a unique system that completely eliminates any unwanted movement at the moment of locking, making the G2380 ideal when exceptional targeting precision over very long distances is needed.
Take a look at the Gitzo G2380 video head and you can see it's something special. Yet, the innovative design is much more than cosmetic. It has been painstakingly developed to eliminate all unnecessary weight, while maintaining the strength, long-lasting durability, and extraordinary precision for which Gitzo heads have become famous.
Weighing a mere 3 lbs., the G2380 is perfect for location work and ideally suited for lightweight ENG cameras, DSLRs and DV Cams. With its fluid control, the G2380 provides exceptionally smooth pans and tilts. Friction for both pan and tilt planes is fully adjustable to perfectly match the weight of your camera. Tightening a convenient knob in the center of the friction control can also independently lock both movements.
A sliding quick-release plate also allows the camera to be easily mounted and balanced from either the front or the rear, and a built-in secondary safety catch protects the camera from accidentally sliding off the head.
With all this style and features, the G2380 goes one step further and incorporates a pan bar that converts in seconds for either right or left-hand operation. And in addition to video applications, the new video fluid head works well with still photography when controlling long lenses and creating dramatic telephoto pan effects.
specsUnits: Imperial| Metric
front tilt -90° / +90° tilt range
independent pan lock yes
independent tilt lock yes
load capacity 5 kg
material aluminum
pan bars included (no.) 1 number
panoramic rotation 360 °
plate type quick release - with 1/4-20" and 3/8" screws
quick release yes
series 2
tilt drag fluid cartridge with fixed drag
variable balance control friction
weight 1.4 kg
working height 13.5
bradhusick
Price dropped to $199 shipped CONUS. That's more than $100 off!
SOLD PENDING PAYMENT (Ray)
