Results 1 to 4 of 4
Thread: FS: Gitzo Carbon Fiber Tripod,Center Column & Head
    Workshop Member lance_schad's Avatar
    Phila./NY
    1,146
    19
    Wanted to put this up here first before it goes on ebay. This is a personal sale of mine. This equipment is in brand new condition,like new.
    •••Tripod Carbon Fiber****
    The Gitzo G1325 tripod is one of the most popular carbon fiber tripods among nature photographers. It effectively supports long telephoto lenses of 35mm, medium format, and even light view cameras. The G1325 is a three-section carbon fiber tripod with flat plate, ideal for photographic or video work and features interchangeable column capability. The flat plate can be removed and replaced with a grooved rapid column or geared column for extra height. It is also compatible with the Gitzo G1321 leveling base.
    PRACTICAL CONSIDERATIONS
    The three section legs are faster to raise in height while in the field than four-section tripods. The G1325 legs are thicker and sturdier than the finer lower legs of the Gitzo G1348. This tripod is often used by photographers shooting with up to 500mm f/4 or 600mm f/4 lenses, plus teleconverters. Fully collapsed the G1325 is longer than the other popular G1348 and G1548 models, a definite consideration for travel and carrying in the field. Use of a column is not recommended with heavy camera equipment, especially telephoto lenses, as it may cause vibrations during use.
    SPECIFICATIONS
    The G1325 series 3 tripod is made with carbon fiber and has a gray and black enamel finish. It is rated for still photography and video use, and has a flat plate column type.
    Maximum Height -58.3
    Minimum Height-4.3"
    Closed Length-26.4"
    Leg Sections - 3
    Maximum Load Capacity - 26.5 lbs
    Weight -4.5 lbs
    List Price ~$600
    Asking: $450.00
    ***Gitzo G-1317 Compact Rapid Column - Aluminum -
    Extends to 11.4"
    List Price ~$100
    Asking: $50
    ****Gitzo G1376M - GitzoG-1376M Magnesium Universal Ballhead with Independent Panning Lock & Quick Release
    Maximum Camera Supported -Standard size medium format
    Load Capacity 13.25 lb (5.90 kg)
    Height 5.5" (14.0 cm)
    Quick Release Yes (with secondary safety lock)
    Separate Panning Lock
    Yes
    Tripod Mount Thread Size
    3/8"-16
    Weight
    2.07 lb (0.94 kg)
    List price $~300.
    Asking $200
    Shipping will be actual cost. Payment via PayPal preferred.
    Lance Schad
    [email protected]
    610-496-5586
    Phila./NY
    1,146
    19
    Re: FS: Gitzo Carbon Fiber Tripod,Center Column & Head
    Forgot the GitzoG-1376M Magnesium Universal Ballhead with Independent Panning Lock & Quick Release picture!
    Phila./NY
    1,146
    19
    One more try!
    Phila./NY
    1,146
    19
    OK $500 for the whole kit, Tripod,Center Column and Head.
    Lance Schad
    [email protected]
    610-496-5586
