Page 2 of 2 FirstFirst 1 2
Results 51 to 55 of 55
Thread: SOLD: Arca CUBE(!!!)
  1. #51
    Aug 2008
    Carmel/Tucson
    2,355
    Re: SOLD: Arca CUBE(!!!)
    Matt - I actually might have one in the dark corner of a cabnet - let me check later today and I'll see if I can find it. ...
    Don
    Similar to Jack's warehouse, but Don's cabinet is in a secured warehouse facility in Tucson....
  2. #52
    Los Altos, CA
    10,486
    1031
    Ah, this explains the detailed explanation of what he thought my facility looked like -- turns out he was self-referencing!!! Explains a lot actually...
    home: www.getdpi.com
  3. #53
    4,333
    Okay seems my secret has been revealed...
    On the other hand I found the Op/Tech which as it turns out (I guess) is the larger one as there's several inches left from the top of the head to the top of the bag. While it covers the head there's also a lot of excess room so I don't think this is going to be as good a fit as the smaller one.
    Don
    Don Libby
    Iron Creek Photography
    Blog
    Tucson AZ
  4. #54
    Nov 2010
    NYC
    1,575
    4
    Don,
    No problem. I'm keeping the tripod and cube in a tough nylon carrying bag for now (Kinetics, I think). It will do till I locate the perfect neoprene sack.
    Thanks much,
    Matt
  5. #55
    4,333
    Actually I normally keep mine in a padded tripod case too. The case sits in the rear of my jeep and helps protect it. If I were to travel by any others means other than my jeep I'd most likely remove the head from the tripod and pack it separately using either the leather bag or an old sock - probably an old sock. I've had my Cube now going on 2-years and it has traveled well over 20,000 in the back of my jeep with no ill effects.
    Don
    Don Libby
    Blog
    Tucson AZ
