Results 1 to 3 of 3
Thread: FS: Milich coded Zeiss 18mm ZM 6-bit flange and WATE adapter
    Senior Member Don Hutton's Avatar
    607
    13
    1. Milich adapter for UV/IR filter on a WATE - includes genuine Leica UV/IR filter - what you need on the M8/M8.2 - goes in between the lens and the WATE hood. $100 shipped and Paypalled - lower 48.
    2. Milich bronze replacement flange for using the 18mm Zeiss ZM on the M8 or M9 - has 6-bit detents milled into it; brings up the correct framelines for the M8 too. Perfect condition (currently coded as a Leica 18mm, but you can easily clean out the current coding configuration with acetone - it is done in nail laquer) - $75 shipped and Paypalled (lower 48). Unscrew your old flange, screw this one on and you're set.
    Aug 2008
    Dallas, TX
    819
    Re: FS: Milich coded Zeiss 18mm ZM 6-bit flange and WATE adapter
    I'll take the 18mm Zeiss flange, PM sent.
    607
    13
    Zeiss flange is sold to John; WATE adapter is still available.
