Results 1 to 5 of 5
Thread: Soviet wide angle lenses with 6-bit coded adapters
    Member voe's Avatar
    Aug 2010
    Melbourne, Australia
    63
    Jupiter 12 35mm f/2.8 + 6-bit coded adapter
    Lens is clean and working perfectly on M8 and M9.
    $80AUD
    Orion 15 28mm f/6 + 6-bit coded adapter
    $140AUD
    4/5774652355_3e907ac026_b.jpg[/url]
    Member voe's Avatar
    Aug 2010
    63
    Re: Soviet wide angle lenses with 6-bit coded adapters
    Bump.
    Member voe's Avatar
    Aug 2010
    63
    Bellow are two untouched samples from Orion-15 28mm lens. Follow the flickr links if you want to see full size taken with M9.
    L1000828 by Voe., on Flickr
    L1000782 by Voe., on Flickr
    Member voe's Avatar
    Aug 2010
    63
    Orion-15 is gone.
    Jupiter-12 35mm and with the 6-bit coded adapter still available.
    Sep 2009
    233
    Any samples from the Jupiter-12? To be honest I am just curious as I don't have a camera that can use this lens (it protrudes too far back for NEX and M 4/3.)
    Thanks, Steve
