Results 1 to 4 of 4
Thread: FS: Leica Summicron 5cm F2, LTM, First Version
    May 2010
    430
    For sale is an early Leica Collapsible Summicron 5cm F2 in Leica in Thread Mount. This is a “Hot-Glass” lens that uses thoriated glass. This lens was “sun bleached” to reduce the amount of yellowing in the glass. It was then cleaned and relubed after this process. The optics are very clean for a Summicron of this vintage, see close-ups of the front element. My other Summicron was like wax paper before going to Focalpoint. Cosmetically it is in EX+ condition.
    This lens would be perfect for black and white film, or for the new M9 monochrome. On a color camera, it will produce a slight yellow cast which can be corrected using color-balance. Thoriated glass was used for its low-dispersion properties: the Infrared Focus index for this lens is within the F2 DOF marks. Not an “APO-Summicron”, but it does not get much better than that.
    Price: $600 shipped within the United States, $625 anywhere else via International Priority Mail. Paypal, Personal Check, Money Order. I reserve the right to hold shipment until check/MO clears. Return policy: returns must be made within 10 days, refund for the price of the item will be given after receipt. Postage cost is not refundable. Front cap and plastic rear cap included. If you need an IR cut filter for use on an M8, I will include one for an extra $30.
    May 2010
    430
    Re: FS: Leica Summicron 5cm F2, LTM, First Version
    Bump and an Up.
    I will include either:
    1) Leica Yellow and Leica Red Filters;
    OR
    2) The UV/IR cut filter with the lens
    The Leica front cap as shown, and a generic metal rear cap included.
    Oct 2011
    Australia
    317
    gorgeous lens
    May 2010
    430
    A Bump. and self-serving Ebay insanity. Found a lens that is from the same block as mine.
    Okay- my lens uses thoriated glass.
    This guy's lens uses "unobtanium"...
    N.Mint Leica Leitz Screw Summicron 5cm f2 lens No.1040316 Lantharum Glass 1952 | eBay
    "Lantharum"???
    He meant Lanthanum, which was used in the later collapsible Summicrons. The switch-over to Lanthanum occurred somewhere in the 104xxxx block, but probably after these two.
