Guy Mancuso
Administrator, Instructor
Im actually going to get a smaller monitor with my new desk im a little too big.
Now they dont make this model currently but do make a newer version with the Spectra Calibration software and puck like this one.
NEC LCD3090WQXi-BK This is with the SpectraView software and the puck . Plus I am also including the Apple Dual DVI adapter
Mini DisplayPort to Dual-Link DVI Adapter - Apple Store (U.S.)
Here are the specs on it.
NEC MultiSync LCD3090WQXi-BK LCD Monitor
29.8 inch LCD Flat Panel Monitor Display
97.8% coverage of AdobeRGB (102% color gamut size vs. NTSC [1953])
Auto Luminance control with X-Light™ Pro backlight/sensor design for consistent brightness and color
ColorComp™ technology compensates for slight variations in luminance and color uniformity, providing even color across the screen
IPS active matrix LCD provides superior screen performance, including wide viewing angles, lifelike flesh tones and dark black levels
Supports internal programmable 12-bit lookup tables (LUTs) for calibration
High resolution (up to 2560 x 1600) allows for more content to be displayed on a single monitor
Gain a new perspective on your desktop with the 30" NEC MultiSync LCD3090WQXi-BK, a widescreen LCD display loaded with advanced technologies and features. Your productivity will soar with this model’s wide-format (16:10) design, which provides roughly the same work area as two smaller-sized displays and allows you to simultaneously view/work in multiple application windows. Achieve unrivaled color performance with a wide color gamut, a 12-bit lookup table, and X-Light™ Pro and ColorComp™ technologies.
Product Specifications
Viewable Image Size 30" (29.8)
Pixel Pitch .251mm
Pixels Per Inch 101
Brightness 350 cd/m²
Contrast Ratio 1000:1
Viewing Angle 89°/89°/89°/89°
Response Time 6ms G-T-G (12 ms)
Synchronization Range (H) 24.0 - 93.8 KHz
Synchronization Range (V) Video band width / Pixel Clock: 25.2 MHz to 268.5 MHz(DualLink)
Input Signal (Video) ANALOG RGB: 0.7 Vp-p/75 Ohms
Input Signal (Sync) Separate Sync: TTL Level (Positive/Negative)
Composite sync: TTL Level (Positive/Negative)
Composite sync on green: (0.3 Vp-p negative 0.7Vp-p positive)
Input Connectors DVI-D (HDCP), DVI-I (digital/analog)
Native Resolution 2560 x1600 @ 60 Hz
Power Consumption (On) 143W
Power Savings Mode 1.3W
Dimensions (WxHxD) w/stand 27.1" x 18.8 - 26.3" x 13.5" 687.3 x 478.6 -668.6 x 342.8mm
Dimensions (WxHxD) no stand 27.1" x 17.6" x 5.0" 687.3 x 446.8 x 126mm
Weight w/stand 40.7 lbs / 18.5kg
Weight no stand 31.9 lbs / 14.5 kg
VESA Hole Configuration 100 x 100mm and 200 x 100mm
Warranty 4 years / 48 hour exchange
Additional Features Ultra-thin frame (bezel), No Touch Auto Adjust, NaViSet software, tilt, VESA Mount, sRGB, tilt, swivel, height-adjustable stand (190mm), pivot, quick-release stand, vacation switch, 12-bit LUTs, black level adjustment, AmbiBright, ColorComp, overdrive, Eco-Mode, real-time clock, X-Light Pro, Analog/Digital CableComp, TileMatrix, TileComp, GammaComp MD software, standalone calibration, SpectraView software-enabled, Windows Vista Premium-certified
I am asking 1600 for it. Shipping is 75 dollars . US only
Pixel Pitch .251mm
Pixels Per Inch 101
