Results 1 to 2 of 2
Thread: FS: Bessa R LTM Rangefinder, 12mm Filter Adapter, Finder
    Nov 2011
    25
    [B;]Voigtlander Bessa-R:[/B]
    All-manual rangefinder with TTL metering at a significantly lower price than a comparably equipped Leica M camera. Discontinued, Rare!
    Black Finish; Like New Condition!
    With camera case!!!
    Camera Type: Modern 35mm rangefinder camera system with interchangeable lenses.
    Viewfinder: Coupled rangefinder with adjustable frame lines and automatic parallax correction.
    Lens Mount: 39mm L-screw mount
    Shutter: Mechanically controlled, vertically traveling metal focal-plane shutter with speeds of 1 second to 1/2000 second, plus Bulb. A second shutter is used to ensure there is no light leakage.
    Exposure meter: TTL (through the lens) system that employs a silicon cell, which reads light reflected from the 18%-gray colored shutter curtain. Center-weighted averaging meter is linked to three LEDs inside viewfinder.
    ISO Range: ISO 25-3200 by 1/3 steps
    Film Advance: Single-stroke non-ratcheted lever with 135-degree throw and 30-degree standoff.
    Self Timer: Non-cancelable self timer with 10-second delay.
    Flash Terminal: Hot shoe on top of camera for nonproprietary flash. Also, X-synchronization terminal on the side of the camera. Camera synchronizes with flash at 1/125 second or slower.
    Dimensions: 5.3 x 3.1 x 1.3in/135.5 x 78.5 x 33.5mm
    Weight: 11.2oz/320g
    ALSO:
    Voigtlander 12mm lens Filter Adapter for in box (for 77mm filters)
    $50 shipped
    Leica eveready half case for M8/M9 $50 SHIPPED:
    (only top portion, bottom half not included)
    12mm Voigtlander viewfinde
    Cracked but still sorta usable (over $200 new)
    $50 SHIPPED
    Nov 2011
    25
    Re: FS: Bessa R LTM Rangefinder, 12mm Filter Adapter, Finder
    Still available!
