Results 1 to 2 of 2
Thread: FS: Alan Gordon The Pocket Mini - 11x Telescoping Director's Viewfinder
    Senior Member bradhusick's Avatar
    Seattle, WA USA
    2,498
    53
    Original owner selling new-condition with neck strap and pouch. Sells for $229.50 on Alan's site. Here for $160 shipped and paypaled in CONUS. Nail polish not included.
    Perfect for seeing composition with different focal lengths before mounting a lens on any camera.
    The Pocket Mini Director's Viewfinder is a proven, versatile accessory for directors, cinematographers, production designers, set builders and location scouts in the film and television industry. Used as recommended this instrument will improve creativity and flexibility in defining choices of lenses, angles, and coverage on the set or location.
    The Pocket Mini Director's Viewfinder features various aspect ratios for you to choose from. Various lens focal lengths are clearly marked along the barrel of the Director's Viewfinder providing you with rapid selection of lens focal lengths. The Collapsible Rubber Eye Cup can be collapsed to a folded position thus allowing those wearing glasses to position the finder close to the eye for maximum clarity of viewing and prevents the scratching of your glasses. You may gently turn the rubber eyecup counter clockwise to adjust the focus. Telescopes from 2 1/2" to 3 1/2".
    New Information
    The Pocket Mini viewfinder will give you readings for a number of digital sensors within 10% of a given lens focal length. To achieve this, set the aspect ratio ring to 16X9 and read the 35mm column. The finder is now set for Super 35 and this setting is also true for the following digital camera sensors: Arri Alexa, Sony F35 PL, Sony F65, Red Epic-X, Red Scarlet, Red One, Canon 7D, and the Phantom HD Gold.
    Specifications
    Aspect Ratios: TV (4:3), 1.66, 16:9, 1.85, 2:35, 2.55
    S16 range: 10mm - 114mm
    35mm range: 18mm - 200mm
    Anamorphic range: 35mm - 400mm
    1/3" sensor range: 3.9mm - 44mm
    1/2" sensor range: 5.2mm - 58mm
    2/3" sensor range: 7.2mm - 80mm
    Brad Husick
    Seattle, WA USA
    2,498
    53
    Re: FS: Alan Gordon The Pocket Mini - 11x Telescoping Director's Viewfinder
    bump
    Brad Husick
