XPAN I System - $4500/reasonable offers
felix5616
Hasselblad XPAN I body with 30mm lens, caps, hood, center filter and viewfinder, 45mm lens with caps hood and center filter and 90mm lens with caps and hood. Also includes a Really Right Stuff L bracket, hasselblad strap. The XPAN body has typical edge wear on the corners but otherwise is very clean and fully functional. All the lens surfaces are unblemished, no scratches, fungus, or coating defects. All lenses come with front and rear caps and corresponding hood(the 45mm and 90mm lens share the same lens hood and center filter). There are 2 center filters, one for the 30mm and one for the 45mm/90mm. The 30mm lens shows the most wear, paint loss on the edges of the f stop ring. The 30mm lens focusing ring is stiff but focuses throughout it entire range , no returns because of this. The inside of the camera is clean, the viewfinder is clear and shutter speeds are accurate. The frame spacing is consistent and accurate. The 30mm lens will benefit from a cleaning but it has never been a problem to use.
