Results 1 to 2 of 2
Thread: Gitzo GS3511S Compact Rapid Carbon Fiber Center Column
    Feb 2012
    109
    Gitzo GS3511S Compact Rapid Carbon Fiber Center Column is for use with the Series 3 6x tripods in the Systematic line. Since these tripods accept interchangeable center columns, this compact column can be used to take full advantage of the variable leg spread on these units, so that you are not inhibited by the length of the column as to how low you can go. Spring loaded hook at bottom of column
    Material: Carbon Fiber
    Travel Distance: 12.2" (31cm)
    Height: 15.75" (40cm)
    Weight: 1.1 lb (490g)
    This items sells new for $165.00. I am selling this Gitzo Center Column for $85, including free ground shipping to continental USA only.
    Feb 2012
    109
    Re: Gitzo GS3511S Compact Rapid Carbon Fiber Center Column
    This item is Sold.
