Results 1 to 3 of 3
Thread: Gitzo G2271M Rationnelle Magnesium tripod head
    Feb 2012
    109
    This head sells new for $335 at B&H Photo in New York.
    Sale Price: $265 includes ground shipping Continental USA.
    See also my separate sale for a GT3541XLS Systematic 6X Carbon Fiber Tripod & a Gitzo GS3511S Center Column. Payment via check, electronic bank transfer, or PayPal.
    Thanks, Mark W. [email protected]
    To see photos go to: Gitzo G2271M Rationnelle Magnesium tripod head
    The Gitzo G2271M is a low-profile Rationelle head that is efficient and silky smooth due to an advanced built-in fluid-effect system, which makes it not only ideal for photographic use, but also birdwatching and mini DV cameras. Made of high quality low weight magnesium, the G2271M comes with a fixed short plate (platform) and is designed to carry a maximum capacity of up to 12.2 lb. The G2271M also comes with multiple spirit levels to ensure that the head is perfectly level, while the ergonomically designed pan and tilt handles feature easy-to-use triangular shaped rubber grips. For more convenience, the tilt handles can be positioned on either the left or the right hand side of the head.
    The G2271M plate has "anti rotation" pins to ensure that the camera remains perfectly stable when shooting in portrait mode. These anti-rotation pins are stored in pre-drilled holes under the head when not in use. Complimenting this is a redesigned large hexagonal thumbscrew on the bottom of the camera locking screw which now makes it easy to attach and remove equipment to the head.
    Magnesium model which offers weight savings of up to 20%
    Offers +95/-60 tilt and +100/-100 side tilt
    Head Type: 3-Way pan/tilt
    Maximum Camera Supported: 35mm, Medium or large format camera
    Load Capacity: 12.2 lb (6 kg)
    Height: 3.9 (10 cm)
    Spirit Level: Yes
    Tripod Mount Thread Size: 3/8-16
    Weight: 1.54 lb (700 g)
    Feb 2012
    109
    Re: Gitzo G2271M Rationnelle Magnesium tripod head
    This Gitzo tripod head is still for sale! I have dropped the price to $235, including ground shipping to continental USA.
    Feb 2012
    109
    THIS ITEM IS SOLD !!!
