Results 1 to 2 of 2
Thread: FS: HORSEMAN VCC PRO Nikon Mount and LENSES 120mm & 80mm
    Senior Member Antonio Chagin's Avatar
    Jul 2008
    Miami-Fort Lauderdale
    476
    Hello I have for sale an excellent Horseman VCC Pro Nikon Mount very little use along with two lenses.
    Horseman VCC Pro with 2 39mm boards.
    Rodenstock APO Rodagon D F:5.6 taking lens 1:1 Macro
    Schneider Componon S 80mm F:4
    All three for $1950 + Shipping PayPal only.
    Would trade for an A7R + normal or kit lens
    The Horseman VCC PRO View Camera Converter enables a full range of camera movements to be utilized when photographing with a Nikon F-mount DSLR camera.
    Allowing you to control perspective distortions and achieve unique depth of field effects. As the central component within a modular system, the VCC PRO includes the dedicated camera adapter as well as an M39 lens panel, and also supports the use of a wide array of large and medium format lenses. The VCC PRO's relatively compact, lightweight form factor and ability to accept a wide variety of lenses makes it ideally suited to use on location, as well as in the studio.
    Once the Nikon F-mount DSLR camera is attached to the VCC PRO body, it can be switched between horizontal and vertical shooting orientations by simply turning a knob, rather than re-orienting the entire camera. The rear standard also incorporates a spindle drive that permits 30mm of vertical movement and 40mm of lateral movement for seamless stitching of multiple frames, with the ability to lock the camera in place for greater precision. The use of a bellows for focusing also better enables making close-up imagery without the need of extension tubes or an additional bellows.
    Camera Movements
    For precise perspective and focusing control, both front and rear standard movements can be used.
    Front Standard:
    Tilt: 15 forward / 10 backward
    Swing: +/- 15
    Shift: +/- 1.2" / 30mm
    Rear Standard:
    Rise/Fall: +/- 0.6" / 15mm
    Shift: +/- 0.8" / 20mm
    Rear Standard Features
    An integrated spindle drive on the rear standard permits seamless stitching of multiple frames in order to accomplish panoramic-type imagery. This rear drive allows fluid movement of the mounted back with secure locking at each position for greater accuracy.
    Modular System
    This view camera converter is the central component within the VCC system, and allows you to pair a Nikon F-mount DSLR camera along with large or medium format lenses.
    ACH
    Jul 2008
    476
    Re: FS: HORSEMAN VCC PRO Nikon Mount and LENSES 120mm & 80mm
    Bump anyone?
