Results 1 to 1 of 1
Thread: FS: 32mm Rodenstock HR Digaron W, Arca Swiss lens mount
    Member Kevin Sink's Avatar
    Jan 2012
    Mission, Kansas
    25
    2
    The optical engineering of this lens is simply superb. Opening up your raw files in LR or Capture One, then applying some sharpening will blow you away. This lens has to be one of the best wide angle lenses ever made. Itís stunningly sharp when centered on the P65 sensor, with only modest sharpness & illumination fall off in the corners.
    Excellent condition
    Very fast & easy to use. The depth of field is so robust at f8 to f16 that focusing and tilt adjustments are greatly simplified.
    Barrel distortion is minimal when sensor plane is perpendicular to the horizon.
    Image Circle: 90mm
    Filter Thread Size: 86mm
    Focal Length Equivalent on 35mm DSLR: 21mm
    Accessories: Lee Filter wide angle bellows lens shade with mounting ring (This system also serves as a filter holder) - a $275 accessory included in asking price
    Price: $6,000 (bought new for $8,550)
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	114708   Click image for larger version.
    Attached Images Attached Images
