Results 1 to 3 of 3
Thread: FS: Hasselblad Xpan + 45/4mm + 90/4mm BOXED.
    Nov 2011
    Stockholm, Sweden.
    1,234
    Hasselblad Xpan Set
    Camera body, and both lenses with original box, complete documents, all three with inspection certificate with matching serial and manual for all three items (Camera + both lenses). Camera body box also includes manual, registration card, novelty xpan stickers, shoulder strap and more. Also included is the very sought after center filter (very expensive filter!), for both lenses but mainly to be used on the 45mm with transparency film between f4 & f8 according to manual, pictured to the left of the image. Boxed original lenshood for both lenses, and red filter for deep dramatic clouds when used with black & white film. All items in perfect functioning condition, meter, viewfinder, knobs etc. Focus & aperture like butter on lenses. Both lens body mint, coating clear & clean aperture blades, no oil. Camera body in Mint- condition, has some very minuscule scratch marks on bottom panel, viewfinder clean, light meter working & accurate. Does not have "battery drain" issues. 90mm lens surfaces are mint, 45mm rear surface mint, front mint- with minor wear, nearly invisible. No haze, no fungus, no separation, no white spots in any of the lenses. All knobs responsive & sturdy. Rangefinder patch in accurate and clear & bright condition. Comes with a used & exposed roll of film inside, so you can test that film advance works etc. Complete package!
    Price: $2199
    Nov 2011
    Stockholm, Sweden.
    1,234
    Re: FS: Hasselblad Xpan + 45/4mm + 90/4mm BOXED.
    UPDATE: Someone asked in a message, the camera exposure count on the LCD says "222", which means camera has run about 2220 exposures, around 104 rolls, if all exposures are 65x24 format, quite low milage!
    Nov 2011
    Stockholm, Sweden.
    1,234
    Sold, thread closed.
