Results 1 to 9 of 9
Thread: C-Mount adapters for Panasonic G1
    Nov 2008
    3,848
    Just received a shipment of the Taiwan (Hawk Peng) adapters, $49 delivered. Also can machine c-mount lenses to fit.
    Kloyy
    Re: C-Mount adapters for Panasonic G1
    PM sent for 1 pc.
    144
    Robert,
    Sent you email for three.
    Paul
    Nov 2008
    3,848
    Just received the MS Optical c-mount adapters. This one has a really nice feature - the center part of the adapter (the c-mount thread) is removable, so the lens can be oriented properly in the mount. This way the focus scale is easily readable.
    Since the thread is removable, it can first be placed on the lens, the the lens & thread can be placed into the adapter. If the thread does not fit into the adapter completely flush, this is a good indicator that the rear of lens will need machining for proper infinity focus.
    The c-mount thread is secured in the mount by set screws.
    The MS Optical c-mount adapter is $119 delivered.
    Jan 2009
    College Place, WA.
    790
    Robert,
    I'm curious about the inside diameter of the MS Optical adapter compared to Hawk's adapter. Larger? Same? Didn't I see a picture of your's with an adapter machined?
    I like the idea of moving the focus scale--mine are all over the place.
    One last thing--could you show a picture of the other side with the set screws?
    Thanx--Bill
    Nov 2008
    3,848
    Bill, it's pretty much the same...both adapters have reached the limit due the the size of the m4/3rds mount itself. To mount larger diameter lenses requires machining.
    The machined adapter you saw was an earlier Hawk adapter; the latest model is slightly expanded to match the one I machined.
    The set screws are on the side of the m4/3 flange, I can take a macro shot and post it.
    Nov 2008
    3,848
    Here is a photo showing one of the set screws that secure the c-mount thread ring.
    Nov 2008
    3,848
    bump
    Kloyy
    C mount adapter received. Also other adapters and lenses. That was fast, Monza.
