jordanreeder
Cambo Actus DB2 View Camera Kit (all gently used, in great condition)
$2,500
Base kit comes with:
175mm monorail
front assembly
rear frame
standard bellows
Also comes with the following:
300mm monorail
300mm bellows
Copal 0 lensplate
Phase One IQ Rearplate
I'm located in San Jose, CA. Will only ship to USA.
Paypal Verified only.
Thanks!
Jordan
https://www.cambo.com/en/actus-series/actus-db2-view-camera/
From the Cambo website:
Cambo ACTUS-DB2 Specifications
Size L / W / H:
18 x 10 x 21 cm
Weight:
1200 grams
Front Swing:
360 degrees
Front Tilt:
19 degrees (+10/-9)
Rear Shift Vertical:
27mm (12/15)
Rear Shift Horizontal:
40mm (20/20)
Max. Extension:
150mm (with standard monorail)
(standard rail has infinity marks for Rodenstock and Schneider lenses)
up to 295mm (with optional long monorail)
up to 445mm (with optional macro-monorail)
Lens plates options:
Copal 0
Copal 1 (Copal 3 on request)
Adapting plate for short barrel Alpa lens panels (short barrel only)
Adapting plate for short barrel WideRS lens panels (short barrel only)
Available Colour:
Black anodised
$2,500
175mm monorail
front assembly
rear frame
standard bellows
300mm monorail
300mm bellows
Copal 0 lensplate
Thanks!
Jordan
Size L / W / H:
18 x 10 x 21 cm
Weight:
1200 grams
Front Swing:
360 degrees
Front Tilt:
19 degrees (+10/-9)
27mm (12/15)
40mm (20/20)
Max. Extension:
Copal 0
Available Colour:
Black anodised
