For those of you wanting to get back to the basics of photography, here is one of the best designed 8x10 cameras ever, a Toyo 810MII 8x10 metal field camera. This camera combines portability, features and rigidity like no other of its type.
Features:
- Precision all metal folding field 8x10
- Weighs only 15 lbs.
- Reducing backs for 5x7 and 4x5 format
- Triple extension bed
- Front standard reverses for extension
- Teflon coated rack and pinion focusing
- Precision composite control knobs
- Independent locks on all movements
- Reversible 8x10 back
- Wide frame design utilizes 158mm square lens boards and minimizes internal vignetting
- Pro black matte finish
Technical Specifications:
Camera Back reversible
Manual Rise front only 90mm
Manual Shift front only 80mm
Swing front/rear 360/12°
Base Tilt front & rear 105°
Interchangeable bellows Yes
Triple Bed Extension with geared back focus built-in
Maximum Extension with front reversed 820mm
Longest Lens with Standard Bellows 800mm T
Shortest Lens with flat Lens Board 100mm
Longest lens f/ Recessed LB & WA Bellows recommended for max. movement 90mm
Shortest Lens with Rec. LB & WA Bellows 58mm
Weight 15 lbs. / 6.8 kilos
Folded Dimensions 14.5" x 15" x 6.2"
This camera is in excellent condition, with very minimal signs of usage. It has a new standard 700mm+ bellows from China. All movements are smooth, and the locks are firm.
Photos:
Price: Toyo 810MII with new bellows, original Toyo WA bellows AND the following accessories:
1. Flat Linhof Lens Board Adapter
2. Recessed Linhof Lens Board Adapter
3. Toyo Compendium Hood
4. Dedicated Camera Case
306,000 JPY / ~2840 USD, INCLUDING worldwide EMS shipping.
Payment is in Japanese Yen, payable via Paypal invoice or bank transfer through TransferWise.
Thanks for looking,
Kumar
Features:
Photos:
Thanks for looking,
Kumar
