jordanreeder
Sony Sonnar T* FE 55mm f/1.8 ZA Lens - $700
Mint- condition. Email me and I can send photos. Or click here: 55mm | Photography | Advertising & Corporate Photographer | Jordan Reeder Photography
Comes with caps and lens hood.
Jordan
Based on the Zeiss Sonnar optical concept, this lens uses a design with seven elements in five groups that helps achieve the large maximum aperture of f/1.8 while simultaneously reducing flare and improving contrast.
A normal-length prime designed for full-frame E-mount cameras, this 55mm lens will provide a excellent perspective for street photography, portraits, and general-purpose shooting. It can also be used on APS-C format cameras where it will provide an equivalent focal length of 82.5mm.
The f/1.8 maximum aperture allows users to create images with shallow depth of field and work in low-light conditions with relative ease.
Zeiss T* anti-reflective coatings have been applied to each lens surface to help minimize reflections in order to provide greater image clarity, contrast, and color fidelity.
Three aspherical elements, including two double-sided, are incorporated in the lens design to reduce astigmatism, field curvature, coma, and other monochromatic aberrations.
A linear autofocus motor and internal focus design provide quick and precise autofocus performance and enables accurate and silent focusing while recording videos.
Dust- and moisture-sealed design better permits working in inclement conditions and rubberized control rings benefit handling in colder temperatures.
Rounded nine-blade diaphragm contributes to a pleasing bokeh quality when employing selective focus techniques.
Focal Length 55mm
Maximum Aperture f/1.8
Minimum Aperture f/22
Lens Mount Sony E
Format Compatibility Full-Frame
Angle of View 43°
Maximum Magnification 0.14x
Minimum Focus Distance 1.64' / 50 cm
Optical Design 7 Elements in 5 Groups
Diaphragm Blades 9, Rounded
Focus Type Autofocus
Image Stabilization None
Filter Size 49 mm (Front)
Dimensions (ø x L) 2.54 x 2.78" / 64.52 x 70.61 mm
Weight 9.9 oz / 281 g
Jordan
Focal Length 55mm
Lens Mount Sony E
Angle of View 43°
