bradhusick
Selling my NEC PA272W-BK 27" 16:9 IPS Monitor (Black). Purchased in 2016, lightly used, no scratches or missing pixels. Calibrates perfectly (calibrator not included). Unused power cable, dual link DVI cable, DisplayPort cable, Hood included. $1400 new. Shipped in factory box (buyer pays shipping, under $48 anywhere in the lower-48, often less if closer to Seattle).
$648.
Specs:
The PA272W-BK 27" 16:9 IPS Monitor from NEC features enhanced color accuracy covering 99.3% of the AdobeRGB color space, 94.8% of the NTSC color space and 146.4% of the sRGB color space. With a variety of input connectors including DisplayPort, Mini DisplayPort, HDMI, and DVI-D Dual-Link inputs you can plug this monitor into a variety of computers. You can also connect USB-compatible peripheral devices to either of the two upstream or three downstream USB ports.
Once connected, this monitor supports resolutions up to 2560 x 1440 with a 16:9 aspect ratio and 6 ms response time. The enhanced resolution and fast response time support enhanced picture quality with reduced lag when viewing fast-moving videos. This VESA-compatible monitor can be mounted to the wall as it supports 100 x 100mm and 100 x 200mm configurations. Whether mounted to the wall or placed on the desktop stand, this monitor can be viewed from a variety of angles as it supports 178° horizontal and vertical viewing angles.
GB-R LED backlight consumes 37% less power than a comparable CCFL backlight
99.3% coverage of the AdobeRGB color space
Enhanced screen performance (1,000:1 contrast ratio, 2560 x 1440 native resolution, 350 cd/m² brightness)
14-bit 3D internal programmable lookup tables (LUTs) for calibration
Five customizable picture modes
MultiProfiler software provides complete control over the five picture modes, including the loading of any ICC profile directly into the monitor for optimal color space matching
DisplaySync Pro controls two computers with only one keyboard and mouse
Wide connectivity includes both regular and Mini DisplayPort with 10-bit support, 10-bit HDMI, a DVI-D input as well as a USB hub
$648.
Specs:
