Profoto Accessories, Dyna-Lite Strobes, Sandisk 2TB SSD Portable
Hi All,
Here are some strobe related items and a new in box Sandisk 2TB SSD. Email with questions :)
Profoto OCF B2, B10, etc. Accessories
$650 for everything. (over $1k new) All barely used.
click here for photos
(2) Extension Cable for B2 Air TTL Off-Camera Flash
(2) Profoto Grid Kit of OCF Flash Heads
(2) Profoto Speed Ring for OCF Flash Heads
(1) Profoto OCF Beauty Dish (white, 24”)
Dyna-Lite M1000wi Kit, $375
Good working condition, awesome workhorse strobes. I just have too many now.
(1) M1000wi 1000ws power pack, built in Pocket Wizard Radio Slave
Dynalite M1000WI 1000 Watt/Second Power includes a built-in Pocket Wizard brand radio slave receiver. This extremely compact power pack is lightweight, precise and powerful. Power may be adjusted asymmetrically in 1/3 power increments between the three head outlets with the rocker switches and across the board with the two-stop dial variator. The M1000WI has a three-way switch for controlling the modeling light -- on full, on in proportion to power, and off. The head outlets are arc-proof -- unplug the heads at will without having to shut down the power pack.
(1) Pelican Case 1600 with padded dividers
(1) Power cord
(1) sync cord
(2) 2040 Strobe heads, 2000w/s
(1) SH2000 Strobe head (glass dome), 2000w/s
(4) Strobe cables
(2) Grid holders (no grids included)
(1) speed ring
(1) pocket wizard PLUS II transceiver
Dyna-Lite M1000xr Kit, $325
M1000xr 1000 ws power pack, with external Pocket Wizard Radio Slave
Power cord
sync cord
(3) 2040 Strobe heads, 2000w/s
(3) Strobe cables
(3) Grid holders (no grids included)
(2) speed rings
(1) pocket wizard MAX
Sandisk Extreme 2TB Portable External SSD, $225 ($300 new on Amazon right now)
Purchased from Amazon last year, I bought 2…this one I never even opened the box (factory seal is unbroken). I thought I needed it for a project. It came with a 3 year warranty, so you have around 2 years left.
Up to 550MB/s - USB-C, USB 3.1
MFR #SDSSDE60-2T00-G25
• High-speed transfers with up to 550MB/s read speeds let you move hi-res photos and videos fast (Based on internal testing; performance may be lower depending on drive capacity, host device, OS and application.)
• Ruggedized, water- and dust-resistant (IP55-rated) (IEC 60529 IP55: Tested to withstand water flow (30 kPa) at 3 min.; limited dust contact does not interfere with operation. Must be clean and dry before use.)
• Shock-resistant solid state core for greater durability (Shock-resistant (up to 1500G) and vibration-resistant (5g RMS, 10-2000 HZ), Non-Operating Temperature(from ‐20°C to 70°C), operating temperature (from 0°C to 45°C))
• Compact and pocket-sized
• For PC and Mac users
• Built by SanDisk, a technology leader and pioneer of the modern day SSD, to deliver superior performance
I'm located in San Jose, CA. Will only ship to USA.
Paypal Verified only.
Thanks!
Jordan
Profoto Accessories SOLD - THANKS!
Dyna-Lite Strobes still for sale (photo links at bottom of thread):
(1) Power cord
(1) sync cord
(4) Strobe cables
(1) speed ring
Power cord
sync cord
(3) Strobe cables
(2) speed rings
One of the Dyna-Lite kits SOLD....thanks!!!
Below is still available:
Power cord
sync cord
(3) Strobe cables
(2) speed rings
