D
DougDolde
My five year old Eizo CG21 is still running strong and appears have as good of an image as it did when new. I can't imagine using anything but an Eizo.
LJ,Tim,
I can appreciate what you are saying and your experiences from you work demands. I guess I am having a bit harder time appreciating just how different these two monitors, from the same company, really are. I am sure the HW calibration and LUT is better in the CG, but if one is running a decent video card already, doing frequent if not daily calibrations, and working in a rather light controlled environment, are the differences really THAT much? I would imagine they are using the same LCD panels, though there might be differences in the QC levels, just as is the case with NEC and Apple.
Please do not think I am being obstinate here. I am really trying to understand just how much difference there is. I appreciate subtle color differences and stuff now, so I agree with what you are describing. Still trying to understand what one is really getting for that premium price. Not adverse to paying it if it truly that much better. Given that most monitors need to be scrapped after 3-4 years of hard use anyway, are the CGs that much of an exception?
LJ
Tim,But when trying to match a client's Corporate color on offset press? Another story. They (clients) are very critical. The price difference I paid for my Eizo-peace-of-mind has more than paid for the Tylenol I would have had to purchase otherwise.
Thanks, David. This is the part that I understand a lot more. (I read the warranty footnote from EIZO in the 30" CG, and it may be 5 years, but they only cover the panel for 3 years or 30,000 hours....bit odd marketing.)LJ,
First off, the Eizo ColorEdge monitors come with a 5 year warranty. They are designed to last longer than standard LCD monitors. A "good" video card is really a moot issue with 2D images. I run an Eizo with a $90 video card. I'm not doing HD video editing or rendering so a higher-end card will make no IQ difference for my photo work. The difference between an 8-bit LUT and a 12-bit LUT is pretty notable. Hardware calibration really works much better - ask around for real life experience on this.
Regarding the panels, you will notice that the specs are different regarding illumination and contrast ratio. So, either they are using the same panels with better CCFL backlighitng or the panels used are different as well. I know that all the LCD panels used in the CG line (except some models like the CG211) use S-PVA. I believe that the SX series uses PVA panels.
If you are looking for a cost-conscious, hardware calibrated Eizo, take a look at the new 22" CG222W for $1,400. The only drawback with this monitor is the screen resolution of 1680x1050. Or go to the 24" CE240W for $1,675. You'll get 1920x1200 res with a trade-off of 10-bit LUT vs. 12-bit LUT in the CG. For the price of the new 30", you could just get two CG241W monitors with no trade-offs. Or, start with one and add a second later if and when you need it.
David
Hi David,Chris,
The CG line comes with Eizo ColorNavigator software and allows you to perform direct hardware calibration using an i1. The SX line isn't hardware calibrated. Essentially, you are limited to 8-bit LUTs in your video card vs. 12-bit in the monitor's ASIC. Also, the CG comes with a nice monitor hood.
Hope this is the info you're looking for.
David
So, both the SX and the CG have the 12-bit LUT. So it sounds like it's a really really nice $2k monitor hood.Eizo.com said:http://www.eizo.com/products/lcd/SX3031W/index.asp
12-Bit Gamma, 16-Bit Internal Processing
The FlexScan SX3031W comes equipped with EIZO’s latest integrated circuit which has a 12-bit look-up table with a color palette of 68 billion colors from which the most appropriate 16.7 million (8-bits) are displayed. It also features 16-bit internal processing for smooth display of grayscale tones, especially in dark areas of an image which typically are difficult for LCD monitors to display without banding.
So you're saying I should wait until Eizo comes out w/ a display port; if I'm going to go down this road?Guess what - DVI is 8 bits even with an Eizo.
