Results 1 to 5 of 5
Thread: Step rings.
    Sep 2010
    Santa Cruz, CA.
    53
    Step rings.
    Not quite sure where to out this.
    I am looking for a 40.5 to 67mm filter adapter for some view camera lenses. I already have rings to get me from 67mm to 77mm. But I am having a hard time with the 40.5 to 67. I see that Heliopan has one but bhphoto are out of stock and I am having a hard time finding another source.
    Thanks.
    Santa Monica, CA
    2,275
    2
    Re: Step rings.
    It wouldn't be a stock item, and might take several weeks to get, but SKGrimes makes a slip on adapter that slips over the outside of the lens and can be made in whatever filter size you want: Slip-On Filter Adapters SKGrimes
    I've got one that I use for the Schneider 35 and 47 Digitars, and recently ordered one for the 72 and 120. Though the Grimes website shows them in brass, they're made now in a black anodized version.
    Sep 2010
    Santa Cruz, CA.
    53
    Re: Step rings.
    Stephen,
    Thanks for the pointer.
    Can you tell me if it is best to get one of these for each lens? I have 2 lenses that take 67mm inside thread, and 2 lenses that take a 40.5mm inside thread, I am guessing the outside circumference would be the same for those two pairs so technically I could get just 1 of each. But experience may tell you that they are not that easy to get on and off in which case 1 for each lens might make most sense.
    Thanks.
    Santa Monica, CA
    2,275
    2
    Re: Step rings.
    They just slide over the lens, and are held in place by friction between the lens barrel and an O-ring around the adapter. I originally had two, but sold one.
    You can call Grimes if you have any questions.
    Sep 2010
    Santa Cruz, CA.
    53
    Re: Step rings.
    I wrote to them earlier, but in the meantime I was curious about your experience. Thanks.
