Results 1 to 3 of 3
Thread: Dell 4K 24" monitor is ASTONISHINGLY GREAT
    Senior Member bradhusick's Avatar
    Seattle, WA USA
    2,498
    53
    I just received the Dell 24" 4K monitor I ordered in anticipation of receiving my new Mac Pro. I hooked it up to my MacBook Pro via HDMI and calibrated it with an i1Display Pro. The images displayed on it are ASTONISHING. The pixel density (184ppi) is very high and it displays 99% of the AdobeRGB gamut. (The MacBook Pro 15" Retina display has 220ppi and maxes out at 2880x1800).
    Here are Dell's specs:
    Diagonally Viewable Size: 60.47 cm 23.8" (23.8-inch wide viewable image size)
    Aspect Ratio: Widescreen (16:9)
    Panel Type, Surface: In-plane switching, anti glare with hard coat 3H
    Optimal resolution: 3840 x 2160 at 60 Hz (DP1.2*)
    3840 x 2160 at 30 Hz HDMI
    Contrast Ratio: 1000: 1 (typical) 2 Million:1 (Max) (Dynamic Contrast Ratio)
    Brightness: 350 cd/m2 (typical)
    Response Time: 8 ms (gray to gray)
    Viewing Angle: (178 vertical / 178 horizontal)
    Color Support: Color Gamut (typical): Adobe RGB 99%, sRGB 100%
    1.07 Billion colors (8 Bits +AFRC)
    Pixel Pitch: 0.137 mm
    Pixel Per Inch (PPI): 185
    Backlight Technology: LED
    Display Type: Widescreen Flat Panel Display
    Display Screen Coating: Antiglare with hard-coating 3H
    The model is the UP2414Q and it's priced at $1399 before any discounts.
    Brad Husick
    Nov 2010
    NYC
    1,575
    4
    Re: Dell 4K 24" monitor is ASTONISHINGLY GREAT
    Brad,
    What resolution and frequency are you getting driving the Dell from the Macbook Pro?
    Thanks,
    Matt
    Seattle, WA USA
    2,498
    53
    3840 x 2160 at 30 Hz displayport
    Brad Husick
