Results 1 to 9 of 9
Thread: Mac disk space conundrum... HELP!
    Jan 2008
    North Vancouver, BC
    1,168
    I have an iMac 2.93 GHz I7 with a 256GB SSD boot drive. I'm running low on space on the SSD, and when I look at where the space is used, I see that using 'Get Info', my user folder (\Users\myname) reports that its size is 173.66 GB.
    (There is virtually nothing in \Users\Guest or \Users\Shared. I have about 19.42GB in my main Applications folder.)
    The problem is that if I do a 'Get Info' on each of the resident subdirectories, I should have, at most, about 7GB of reported used space.
    Any ideas???
    Also, is there a way from within Finder, to have the Size shown, rather than have to use the 'Get Info' function on individual folders?
    TIA
    Senior Member Per Ofverbeck's Avatar
    Feb 2008
    503
    5
    Re: Mac disk space conundrum... HELP!
    Quote Originally Posted by simonclivehughes View Post
    Any ideas???
    TIA
    OK, last thing first. If you select List view in a Finder window, there should be a column showing the file sizes. If there isn´t, just click Command + J, and check the ´Size´ box in the small window that opens. While there, also check `Show all sizes´ (or something to that effect; I´m on the Swedish version, so I can´t see the exact term used); it´s the third check box from the bottom.
    Now you´ll see everything the Finder wants you to know... Problem is, there are lots of hidden files that take up space without showing up in the regular list, and chances are that your problem is caused by such files.
    There are tools to see, and purge, such files; one good and free one is OmniDiskSweeper. Download it, run it, and see what happens; it will show all files in size order, and you should be able to find out where the problem is.
    IMPORTANT! Unless you really know what you´re doing, do not start deleting files just because they are large and look unfamiliar; it may render the system unable to run! First of all, make a good backup of everything important!
    Senior Member Joe Colson's Avatar
    Oct 2010
    North Carolina, USA
    1,913
    36
    Quote Originally Posted by Per Ofverbeck View Post
    +1
    OmniDiskSweeper is free and quickly shows EVERYTHING. As noted, backup first and delete carefully.
    Joe
    _________________________________
    Joe Colson Photography
    Jan 2008
    North Vancouver, BC
    1,168
    Thanks, Gents, OmniDiskSweeper came through (love the Omni stuff), and the culprit is iOS backups from my two 128GB iPads.
    I've found a Terminal script that will allow me to change the location of the iOS backup folder to my 2TB internal HDD. That alone will free up 135GB on the SSD.
    On a separate matter that I'm puzzling over...
    My Keynote app (on the iMac) is version 6.1, but there is an update to 6.2.2 that I cannot load/update. I tried to trash the file and then re-download it from the App Store, but it still doesn't show an update available.
    The part that stinks is that I was working on a file that now won't open as it says "You need a newer version of Keynote to open this presentation. You can download the latest version of Keynote from the Mac App Store."
    Yeah... that's what I'd love to do, but no joy... any suggestions on this???
    Vancouver, WA
    5,804
    564
    Now this may be a red-herring but there is an OS X 10.9 requirement for Keynote 6.2.2. If you're not running 10.9 then you probably won't get the upgrade option.
    Jan 2008
    North Vancouver, BC
    1,168
    Thanks, Graham, but I'm on 10.9.5 so that shouldn't be an issue.
    I must say, I hate that the updates are now done through the App Store... I don't ever remember having these type of issues with the old Software Update scheme.
    Vancouver, WA
    5,804
    564
    What is supposed to happen is that if you drop keynote in the trash, empty the trash, go to app store, hold down the option key and click on purchases, then you should be able to download KeyNote again. The version it downloads should be the latest 6.2.2.
    If that's not working then I'm not sure what else to suggest.
    Oct 2010
    North Carolina, USA
    1,913
    36
    Yeah, what Graham said. I use an app remover called AppZapper. It's not free, but it removes the app and all its preference files. You can enable it to remove Apple apps as well as apps that are installed from the App Store. Sometimes simply moving an app to the trash leaves residue that prevents the installation of a newer version. Hope this helps.
    Joe
    Jan 2008
    North Vancouver, BC
    1,168
    Well, interestingly, trashing the app and re-installing worked this time, and it installed 6.2.2 right away (instead of just 6.1). So I'm happy camper.
    Thanks gents!
