Tripod questions
cjlacz
I've recently decided to invest in a tripod and I've been reading up on my options here and on other sites, but I wanted to get some opinions before I pull the trigger.
Due to my working hours I'm kind of restricted to a lot of night photography and my E-510 doesn't really cut it. I'd rather not buy a D90/D700. There are a lot of opportunities here in Tokyo to pull a tripod out so it seems like a good investment. It has to be fairly light and compact since I'll be carrying it everywhere. Probably the biggest thing I'd be putting on it is something like the E3 w/ 50-200.
Are Gitzo's 1 series too light for that? I'm getting that impression from what I read. It seems like the GK2580TQR or GT2541 would be a better choice. Has anyone used the former?
They are more money then I'd like to invest, but I don't want something that I'll be unhappy with either. I saw Guy recommended the Induro. I'm guessing the best choice for me would be the C214?
Is there anything else you'd recommend that isn't quite as pricey as the Gitzo, but still pretty good performance?
D
ddk
You should also look at Slik, I know that the brand doesn't have the caché of European products but they make some very good light weight tripods. Its also Japanese so it would cost you less as well.
Godfrey
My most used tripod is a set of Manfrotto 190CXpro3 legs fitted with a Markins Q3 head. Very light (about 3.2 lbs), very sturdy for its size and weight, very quick to use in the field.
When folded, it's about 27 by 3.5 inches and straps onto the bottom of my shoulder bag very neatly, doesn't get in the way too much at all.
It's held an E-1 plus EC14 plus 50-200mm at full tele with the column fully extended very steadily. That's more than I would normally ask of it, of course, but it does it well in a pinch.
O
Oxide Blu
DON'T LAUGH!!! ...
... for the last few months I have not been carrying a traditional tripod -- been carrying a little Joby in my purse, use it all the time with my Ricoh subcompact cameras. They also make a larger size gorilla pod. I have yet to be in a situation where there was not something close by that I could wrap or attach the GorillaPod onto. The raised ridges are rubber -- it'll cling to a glass wine bottle. All plastic, extremely light weight. They come in 4 sizes, will support up 5kg (dSLR + zoom lens). Compared to a traditional tripod ... cheap! :D Available in Nihon. Find 'em at some camera stores but cheaper to buy via mail order in Nihon than in the US -- and Joby is a SF Bay Area company.
http://joby.com/
cjlacz
Thanks for all the tips. I did go out and look a bit more yesterday. I think I like the Silk tripods a bit more than Manfrotto. I'll sit and think on it a bit longer. I do have the large Gorilla pod I forgot about, just haven't used it much. I've found getting it level to be a pain, as well as attaching and removing it from the camera. I might invest in a head with quick release for it first and see about the tripod later.
Terry
I have the 2541 and the 1150T from Gitzo. I've used the 1550 with a full sized dslr. Is it the absolute best, no. Does it work just fine? Yes! I swapped the ball head that came on it to the gitzo 1780 which holds more. The 1550 is great because it is small and light and folds up quite nicely. This is definitely not a low priced option but it is my favorite tripod between the two because I'm more inclined to carry it more often.
Diane B
I just loved that 2nd and 3rd photo of the camera with gorillapod LOL--surreal. For some reason they reminded me of those little robots in the WAll-E movie
I have 2 Manfrottos--a big heavy one I used for commercial work, but rarely pull out now. I have the same 190 legs Godfrey has and I have the heavier Markins head--10L I think--have had it for a longish time and really like it.
cjlacz
Thanks again for all the advice. The recent thread in the MF forum has been useful too. I think I'll grab a ball head for my Gorilla pod first and see how that works out. I almost bought a cheap one, but didn't seem worth it. I'll probably try getting the Gitzo 1780 since that seems to work well on their travel tripods too. After much deliberation I'll probably purchase the GT1541T or GT1550T in the future. Probably with a preference to the latter. I could likely fit that in my bag which would be even better. Weight in particular is important, or I just won't use it. There are a still a few interesting alternatives out there I'll keep my eyes on and see if I can find them in Tokyo to look at.
I appreciate all the help!
kdphotography
Interesting "new" Traveler tripod from Gitzo... a "two" series?
http://www.gitzo.com/Jahia/site/gitzo/pid/4765?kindOfProductCollectionRequest=productDetail&productCode=GK2580TQR&productDescription=SER.2%206X%20TRAVELER%20KIT&curBrandId=BGI&market=MKT1&actualPathCategoryKey=1CAT:AAA1:2CAT:BB59:3CAT:CC49:4CAT<img src=
cjlacz
I just bought the GT1550T during lunch this afternoon. It even fits inside my UD35 w/ my 7-14, 12-60, 50-200, EC-14 and E-510. That probably won't be the base once I upgrade the head.
On a different note, Kirk, Arc Swiss and some other plates and clamps are compatible with Real Right Stuff, correct? I'm not sure I want to put in a RRS order until I upgrade my body, but I'd like to keep stuff fairly compatible if possible.
A
ALau
I suppose it would be good to start with a good one right from the very beginning. When i started out, I purchased two so-so ones, thinking on skimping out on cost from the beginning. In the end, it all adds up and could have been spend on a Gitzo or Bogen. I spent many hours in the store and basicly touching and lifting the tripods from many vendors, seeing which ones felt good and was not too heavy. Ultimately devided on a Gitzo 3530LS. I wanted something sturdy and one that will last.. I didn't care for the center column and glad that I pulled the trigger on it.
Essentially, in recommending a tripod to someone, I would say, save up and buy a good one from the start. Visit a store and see which one "feels" good and fit your style.
simonclivehughes
Actually, both RRS and Kirk are compatible with (and modelled after the) Arca Swiss.
A
ALau
Yikes.. It seems that with every new model Gitzo replaces, the price also heads North.
Easily falls in the neighborhood of a nice piece of glass.
N
nei1
I built a table for my heavy de vere enlarger,solid as a rock,.......couldnt get a sharp print.After much messing around realised the obvious,vibration from traffic and ,possibly,the local train.So I unbuilt the table ,made a base from concrete blocks and the table top from a stack of 3 paving slabs sandwiched with foam backed carpet between each slab.This worked perfectly.
Is this a problem in the tripod world,I imagine it must be ,and is there a solution that is a little lighter and more portable than that for my enlarger?
Dale Allyn
Nei1, we deal with this with photo-microscopy commonly – layering concrete, heavy steel plates, very thick rubber mats, etc. One must find the right combination to isolate the microscope from terrestrial and other vibrations. I've had far fewer problems with conventional photography when using quality tripod, head and weight.
