Results 1 to 2 of 2
Thread: Tifs from 5.1 conversion Trying to open in Camera raw Cs4 or Cs3
    Little Rock AR
    1,925
    3
    I just installed 5.1 (under XP). Processes fine, but when I attempt to
    open a 8 or 16 bit tif created in 5.1 in CS4 or CS3, the file opens in Camera raw instead of the just opening into photoshop. Thus CS4 is seeing it as a raw file.
    Anyone else have this problem?
    I can still develop in Capture One 4.81. with no problems, only the 5.1 version of Capture one causes this. I never installed 5.0. May back off 5.1 and see what happens.
    Paul Caldwell
    Senior Member Scargos2's Avatar
    Apr 2009
    Central Florida
    291
    Re: Tifs from 5.1 conversion Trying to open in Camera raw Cs4 or Cs3
    You need to convert to Tif and select open in CS3 or CS4.
    I have no problem doing this, Good Luck.
    Hope this Helps
    Sunny Florida Rick of Fla
