Results 1 to 6 of 6
Thread: RGB values from 8bit pixel
    faisaldj
    I have selected the color type in my camera as follows
    8-bit Colour (RAW, 332(RGB))
    can somebody guide me a little bit to write the c or c++ code to get
    the rgb values of the pixel.
    with regards,
    Muhammad Faisal.
    Subscriber Member TRSmith's Avatar
    Central Maine, U.S.A.
    2,406
    9
    Re: RGB values from 8bit pixel
    The eyedropper in the info box of Photoshop will do that for you without having to write any code. Simply click and hold the eyedropper icon in the color box and select RGB. After that, wherever you put your mouse pointer you will see the values displayed in the info box for the pixel directly beneath the mouse pointer.
    Administrator Bob's Avatar
    Prescott, Arizona
    4,492
    367
    It depends on the fprmat your camera uses.
    There is some limited documentation available on the web some some camera formats. Canon and dng are probably the best documented.
    Of course, the raw format is usually a pixel array that has been bayer encoded and as such does not actually have an rgb value until converted.
    thanks
    -bob
    faisaldj
    Actually I want to process this data through microcontroller thats why I want to write a c or c++ code
    with regards,
    faisal
    Apr 2010
    Somerset - UK
    92
    Hi Faisal,
    You can probably find some clues on Dave Coffin's site http://www.cybercom.net/~dcoffin/dcraw/
    Best wishes,
    Ray
    Senior Member Lars's Avatar
    Sunnyvale, California
    1,811
    19
    Yep Ray is right DCRAW i a good start. you can also look at the LIBRAW open source project that wraps and extends DCRAW a bit.
    Finally, in case you haven't, this is a good time to read up on color science. Bruce Lindbloom's site is a good reference, but there is lots of material on color science out there.
    Monochrome: http://mochro.com
