Results 1 to 11 of 11
Thread: Best Noise Reduction software
    May 2010
    Perth, Western Australia
    138
    Hi guys,
    Just wondering what noise reduction software is your favourite, no its not for a Hasselblad Shot
    Cheers
    Will.
    www.williamophuis.com
    Hassy H4D-40.
    Senior Member bradhusick's Avatar
    Seattle, WA USA
    2,498
    53
    Re: Best Noise Reduction software
    Lightroom 3 has really good noise reduction built-in. I have tried many of the add-on products and now simply use Lightroom.
    Los Altos, CA
    10,486
    1031
    My favorite remains NIK's DFine, but it doesn't work in 64 bit yet. Also excellent is Topaz labs NR tool.
    home: www.getdpi.com
    Kirk Gittings
    Quote Originally Posted by bradhusick View Post
    Me too. It is much superior to what I was using-Noise Ninja-and does everything I need.
    bruin
    I like Noiseware. It lets me control the NR strength for different frequencies (very low, low, medium, high) and luminance/chroma noise, so I can create a look similar to film grain.
    Los Altos, CA
    10,486
    1031
    I should add after the LR comments that C1's latest NR is also excellent. However, NR in raw converters apply globally, and there are times when you only want to remove noise from certain areas of the image. Here, a "layers and masks" workflow in Photoshop is an ideal solution. The NR tools in CS5 are improved as well, but IMO they still aren't quite up to what the aforementioned plug-ins can do.
    My humble .02,
    Aug 2010
    New Jersey, USA
    509
    Noiseware also. It has some free actions with it, but I find all most all of the time the default works just great. So you can get technical with it or just use it right out of the box.
    May 2010
    138
    Thanks guys, I work in Photoshop cs4 at the moment so can't play with Lightroom, will look into noiseware and Niks, I guess I can always save the image twice and do noise reduction on one and then blend in photoshop.
    Cheers
    Will.
    Hassy H4D-40.
    498
    8
    All the tests I have seen clearly show LR3 noise reduction being superior to C1, but in my own tests C1 was better and more natural looking. I think what camera you shoot with may have a strong effect on what works and what is best.
    Dyslexic3
    I'm as new as new gets around here, but can someone clarify what is abbreviated to C1?
    Tim
    Ventdesable
    Hello,
    New to...
    C1
