Results 1 to 8 of 8
Thread: Phocus + Eizo CG monitor calibration issue
    Sep 2008
    Sydney, Australia
    96
    Bit of a long shot here that anyone can help, but I have noticed some clipping to black of the very dark tones in Phocus recently. Don't know when exactly it started happening, but it seems anything below about 10,10,10 RGB will clip to black, making previews look more contrasty than the exported tiff when opened in Photoshop. This is at any magnification. Quite obvious side by side, with the exported image open in Photoshop next to the preview in Phocus.
    So it looks like I have a monitor profiling issue. The monitor is an Eizo CG243W, which uses a hardware calibration using a Colormunki device. Even though the calibration is hardware, i.e. it produces LUTs in the monitor as opposed to translating colours through software (as far as I understand), the Eizo calibration software also produces an icc file in my profiles folder, which Phocus seems to use. I know this because I trashed it and the colours went haywire in Phocus. So I re-profiled, and a new icc file was created, but the very dark tones are still clipped in Phocus.
    Does anyone else see this issue? Why does Phocus seem to use the software icc file but Photoshop doesn't, allowing the monitor's hardware profile to be used? Am I not understanding it properly? Is it a bug, with either Phocus, the Eizo software or somewhere else?
    Hardware is a 2009 Mac Pro, running OS X 10.8, using Phocus 2.8.
    Any help appreciated.
    Thanks,
    Ben
    Jan 2016
    Re: Phocus + Eizo CG monitor calibration issue
    Bumping this question. I have recently started having this issue.
    Hardware is 2015 Mac Pro trash can running OS X 10.11.1
    When I calibrate the monitor through iOne Display, unchecking hardware calibration, it works fine, but obviously I'd rather use ColorNavigator and the hardware calibration.
    Thoughts?
    Quote Originally Posted by bdp View Post
    Thanks,
    Ben
    Sep 2008
    Sydney, Australia
    96
    This problem resolved itself for me a long time ago. I assume either a OS update, or a Phocus update, or a Colornavigator update fixed it. It was hard to know who to report the bug to at the time, so not sure who you could contact for support. I'm concerned to hear it's back.... Hasn't affected me yet afaik. Keep us updated if you discover a solution.
    Have you tried calibrating the monitor through Phocus? Doesn't it have some sort of Eizo calibration option in the preferences if an Eizo monitor is connected?
    Ben
    Nov 2015
    Sweden
    6
    I have the exact same problem. Using a Mac Pro 2013 with OSX 10.11.2 and Phocus 9.2.2 and a Eizo Color Edge CG243W.
    The preview in Phocus is way too contrasty and clips the shadows compared to the exported tiff that I open in PS CC2015. This only happens when I look at Phocus on the hardware calibrated CG243. When drawing both PS and Phocus over to another cheaper monitor (Eizo Flexscan) it looks the same. It also looks the same in both programs when comparing it on my laptop (macbook Pro Retina).
    So, I guess you are right about how it cant read the right profile from the Eizo CG monitor.
    I got an answer from Hasselblad here in Sweden and they told me Phocus renders the previews with something called Apple Core Image Service, which Photoshop doest. They are waiting for Apple to update the OSX to 10.11.3 which hopefully adress the issue with Apple Core Image Service. So I guess well just have to wait for that and hope they will solve the problem as soon as possible.
    Stefan
    Attached Images Attached Images
    Sep 2008
    Sydney, Australia
    96
    I'm remember a workaround I used to get by when I had this problem, maybe it still works.
    Basically I unchecked an option in the advanced settings of Colornavigator that mentioned something like 'Reflect black point in profile'. I can't quite remember where it is, but will have a look when I get into my studio today.
    Ben
    Sep 2008
    Sydney, Australia
    96
    OK, found it. Try this:
    When creating a new profile, there is the option to Customize Profile (see screen shot)
    Once you click there you can uncheck the option 'Reflect black level in tone curve'.
    Once you create a profile like this Phocus may match the correct black level of the hardware profile more closely. Let me know your results.
    Ben
    Attached Thumbnails Attached Thumbnails Click image for larger version.
Name:	Screen Shot 2016-01-12 at 9.03.29 am.jpg
ID:	115752   Click image for larger version.
Name:	Screen Shot 2016-01-12 at 9.03.39 am.jpg
    Nov 2015
    Sweden
    6
    Hi Ben,
    Well I tried and it seems to work. Thanks!
    It still feels like an unofficial workaround though and Im not really sure what it does. Most photographers out there will probably not do this so I hope it will be an update soon.
    //Stefan
    Sep 2008
    Sydney, Australia
    96
    Hi Stefan,
    That's great. I'm not sure why it works either, but the problem will probably go away when either the OS or Phocus or Colornavigator gets updated.
    Ben
