Results 1 to 3 of 3
Thread: Epson printer incorrectly reporting ink level
    May 2012
    Bay Area
    494
    17
    My Epson 3880 is about two years old. This year, twice now, it appeared that the Photo Black ink was totally clogged. The remaining ink indicator showed about 50% remaining. Both times, after running several cleaning cycles to no avail, I removed the cartridge and saw it was empty.
    FWIW, to avoid reporting errors of this sort, Epson recommends changing ink carts with the printer powered on, which is what I always do.
    Anyone have a similar experience?
    Ed
    Oct 2008
    Hurst, Texas (DFW area)
    179
    Re: Epson printer incorrectly reporting ink level
    I also have an Epson 3880. I have not had that specific problem but my printer has twice reported a missing cartridge on power up.
    I simply remove and reinstall the offending cartridge and all is well. I suspect that the connections between the cartridge and printer are becoming oxidized and a simple cleaning may be in order. In your case, because the printer is not reading the cartridge ink level correctly, replacing the empty cartridge may well fix your issue. It doesn't seem as though the electrical contact interface between the printer/cartridge on the 3880 is a very robust design. Hope this helps.
    Paul
    May 2012
    Bay Area
    494
    17
    Thanks Paul. I actually meant this post to be in the Printing & Output forum but it seems, posting on an iPad, that I missed.
    Ed
