Results 1 to 7 of 7
Thread: Problems with C1 Crashing! Help!!
    Fort Collins, Colorado
    2,077
    Given the success of others I assume the problems I am having with 4.8 must be due to something i am doing wrong. For me, C1 4.8 crashes constantly. Sometimes it takes only 30 seconds and at other times several minutes.
    I completely (or as best I understand "completely") uninstalled the older version of C1 and then did a clean install of 4.8. When I started having problems I ran disk warrior so as to assure I had a clean directory and that all files had disk permission set correctly (or as best I understand "correctly"). No help. Same symptoms as before.
    I have now gone back to 4.7 and although not completely stable it is far better than 4.8
    I am on a Mac (Intel based) and am running the latest update of 10.5.
    Someone please help. I really need C1 but with these crashes I am about to give up. I have run virtually all the other raw converters (ACR, LR, Lightzone, Silkypix, Raw Developer) and have never had crashes. Some of the raw converters mentioned have other issues for sure but stability isn't one of them.
    Thanks in advance for any help
    Doug, where are you now that I really need you
    Woody
    Los Altos, CA
    10,486
    1031
    Re: Problems with C1 Crashing! Help!!
    Woody,
    just to confirm you have followed all of the C1 removal/clean install steps outlined here to the letter:
    http://www.phaseone.com/Content/Supp...4&languageid=1
    home: www.getdpi.com
    2,077
    Woody,
    You are simply superb! it appears that I needed to eliminate the Plist in order to allow a real error free installation. It is now running fine (or at least as good as I can tell after one half hour's work.) Hopefully it will remain stable as I also installed the latest 4.8.1 code.
    Thanks so much for your (as always) great guidance.
    Best
    Woody
    Los Altos, CA
    10,486
    1031
    Glad it helped Woody...
    And why they pay me the big bucks to post here.
    23,623
    2555
    Yes you really need to go in there and find all the crap laying around. One you get rid of everything than the only real guarantee to avoid a crash or a issue. Adobe does the same thing on a Mac crap is everywhere. Glad you got it solved
    www.guymancusophotography.com
    NYC
    3,275
    7
    Quote Originally Posted by woodyspedden View Post
    All is well still?
    Doug
    Doug Peterson (e-mail Me)
    __________________
    Phase One, Canon, Apple, Profoto, Eizo & More
    National: 877.217.9870 | Cell: 740.707.2183
    Newsletter: Read Latest or Sign Up
    2,077
    Quote Originally Posted by dougpetersonci View Post
    All is well still?
    Doug
    __________________
    Hey Doug
    Thanks for taking the time to answer my post. Yes, all is still well. I am now a happy camper
    Woody
