Results 1 to 7 of 7
Thread: Help with C1
    Terry's Avatar
    New York City
    6,955
    1145
    Help with C1
    Kudos to Doug Peterson for being so patient and doing a great job teaching the basics of Capture 1. Unfortunately, now that I'm home I realize that we never made it to the "process" part of the program.
    I used the default process recipe and it created a tiff for me but what I really want to have are different recipes for different outputs (tiffs for CS4, jpegs for the web). I started to change the settings on process pane but it seemed to be making changes to the thumbnails below so I don't want to muck things up until I know how to do it correctly. Is there a way to make and name recipes?
    Los Altos, CA
    10,486
    1031
    Re: Help with C1
    Click the Gear tab for the process menu. In default, the first menu item is the recipe dialog. Set all of your preferred parameters for the recipe at hand, then click the little triangle on the top right of the recipe dialog and one of the options in that dropdown is "Save Recipe" -- click that, give it a name, and you done.
    home: www.getdpi.com
    Terry's Avatar
    New York City
    6,955
    1145
    Re: Help with C1
    Jack,
    I'm not trying to be dense (....it's not working) So here is what I see....
    Attachment 18265
    then if I were happy with everything and go to the drop down I think you are talking about I get this....
    Attachment 18266
    Los Altos, CA
    10,486
    1031
    Re: Help with C1
    Okay. You need to right-click in the tool area and add the "Process Recipe*s*" tool, which is separate from the "Process Recipe" tool! You save the Process Recipe settings with the Process Recipes tool .
    Your process area should look something like this, note the right-click brings up the tool selection list for that tab:
    Administrator Bob's Avatar
    Prescott, Arizona
    4,492
    367
    Re: Help with C1
    Terry,
    I think that might be a C1 Pro feature.
    In any case it is in a windlet (or gadget) named "process recipes" which may be available if you were to right click in he area below process summaries.
    -bob
    23,623
    2555
    Re: Help with C1
    Remember once you get all the tools up you can move them around in the column and ALSO float them anywhere on your screen. You do need the output naming to select the folder and drive you want to output to. Also on Jacks screen grab if you select Jack's standard which he setup for Tif which you can do and also setup a small jpeg if you toggle those two you will get two files processed at the same time, in this case one Tif and one Jpeg. Which is a nice feature. I think you can actually do 4 at once but never tried that. BTW i make this on my third tab in from the left with all my options I use all the time. If i need something else say like crop than I will go to that tab. So I make my primary functions in this tab and secondary in others.
    www.guymancusophotography.com
    Terry's Avatar
    New York City
    6,955
    1145
    Re: Help with C1
    OK,
    I got it. I was in regular Capture 1 and not Pro. Well, there is one reason to immediately get pro. If you can't set up recipes that would be hugely annoying!
