No, the Peak Design anchor "strings" will not fit through the camera strap lugs. I use the Peak Design Leash strap and have installed the O-rings on the camera.Are any of you using the Peak Design strap(s) with the anchors? Can you put the string of the anchor through the strap lug on the camera thus not use the O-rings?
I am not aware of anyone making a dedicated L bracket for the 907 yet. You could use a universal bracket, though--it would fit easily enough. Wouldn't look super 'elegant' but it would be perfectly functional for this use. The only issue would be that the rear screen would be tilted at an odd angle with the camera oriented vertically. Otherwise, should be fine.The 907x looks like a great option to replace a couple of current camera systems. I like to shoot vertical panos to stitch to a horizontal 6:4 or 2:1.
Is there a way to attach the 907X to a tripod in a portrait (vertical) position? I have not seen an L bracket for the camera anywhere at this point.
