A few of the lenses I can put on Sony A7rII
jotloob
Thank you Erik for showing these interesting combinations .
Can you please give some info about what adapter and adapter/lens holder you use for the HASSELBLAD solution ?
Thank you .
Jürgen
ErikKaffehr
The web page has been updated with some more info:
http://echophoto.dnsalias.net/ekr/Articles/A7Flex/
Some interesting stuff:
I five of the examples the HCam Master TSII is shown. This is an adapter with a Sony FE mount on the back and a Canon EF mount on the front. It can be used with all Canon EF mount lenses and yields +/-15 mm shift and 10 degrees tilt.
Shift is useful to avoid converging verticals and tilt allows for tilting the plane of sharpness.
This combo gives my old Hasselblad lenses a new hang of life. The large image circle gives around 12 mm of shift. The same goes for my Pentax 67 lenses.
The Canon 16-35/4 allows some shift and full tilt. The downside is that the lens needs to be stopped down before mounting on the adapter.
The Rodenstock Rodagon 50/2.8 is hopefully usable as a macro lens, and the same applies to the Photar. Here they are shown in the Zork Mini Makro Mount that allows some focusing.
Best regards
Erik
Thank you .
Jürgen
jotloob
Thank you Erik .:thumbup:
Stefan Steib from HCam is not far from my place .
I might contact him and meet him .
ErikKaffehr
Hi Jürgen,
I use the Novoflex adapter on Stefan's recommendation. First I tried the "Fotodiox adapter" but that was quite crappy. The Novoflex is cleanly made. It consists of two parts a Canon back end and a Hasselblad front end.
The Novoflex has rather small internal diameter, but I don't think it matters. There is some shading with shifts above 12 mm, but I think it comes from the internal baffles of the HCam Master TSII.
For the Pentax I bought a Kipon (Pentax 67 to Canon EF) adapter. It is similar to the Novoflex, although the black painting on the inside of the Novoflex is better (more matte and less glossy).
I have tried the Planar 100/3.5 and the Distagon 60/3.5 with "shift panos" on the A7rII the Planar 100/3.5 was pretty good and the Distagon was quite OK.
Best regards
Erik
Thank you .
Jürgen
ErikKaffehr
Some more sample images of the HCam Master TSII
This page shows some more images of the HCam Master TS:
http://echophoto.dnsalias.net/ekr/Articles/Shoots/HCam_Master_TSII/
This page shows some image samples with Hasselblad lenses on the A7rII: http://echophoto.dnsalias.net/ekr/Articles/H_CF_Lenses_on_A7rII/
The Master TSII allows something like 12 mm shift, so, the camera in vertical position and used shifted stitching I can get an image size 48x36 mm, about the same as with my P45+ (49x37 mm), but with twice the pixel amount.
All stitching done in Lightroom.
Best regards
Erik
daf
Re: Some more sample images of the HCam Master TSII
Hi Erik,
Could you check what is the image circle of the 25 photar at infinity?
Thanks a lot
David
