There must be a way to use the TTL triggers... after all, they can trigger my “dumb” AcuteB Air-S units. I have both Nikon and Fuji TTL units so I’ll see if I can get one or both of them to trigger my XF.
Unfortunately I was unable to trigger my XF with my Nikon
or Fuji TTL triggers, which is very odd. While testing I put an AcuteB unit on the same channel and it fired without issue, as did my basic Air Remote in “receive” mode. There must be some difference in the protocol that is not compatible with the transceiver in the XF. Perhaps we should file a bug with Phase One and hope this gets addressed in a future firmware update.
What
would probably work if you could buy or make the cable, would be to connect the 1/8” sync output of the basic Air Remote to the 12-pin cable release input on the XF.
Hello, yes, Fotoflits is the place I got mine from. Works great!
With this tool, the flashes will be fired radiographically as soon as you press the 'measure' button in combination with your Sekonic light meter
www.fotoflits.com
Awesome, thank you both! Will order one.
I have one for my L-758 it has been great... my L-758 is dying and i have a L-858 and Trigger wizard are about to release one for it
