I would have assumed that, had he said 2/3 pi !I presumed 120 degree
I meant 120cm, but I just looked it up and it was actually a 135cm Elinchrom Octa with a reverse mounted headI presume 120mm soft box.
I didin't take a BTS image, but if there is interest I can add them in the futureThank you. The lighting setup was a 120 octa on the left slightly behind the model and feathered, and a V-flat on the right and front as close to the model as I could get it
CFV16 120mm f5.6 S-Planar C TStar Zeiss Proxar .5 Polarizer by Nokton48, on FlickrThis reverse mount?I meant 120cm, but I just looked it up and it was actually a 135cm Elinchrom Octa with a reverse mouted head
CFV16 30MM BLACK TSTAR DISTAGON EI F11 500CM by Nokton48, on FlickrIt wasThis reverse mount?
That pretty much turns the 135 into a mini Indirect Litemotiv Octa 190. Interesting... Anyway, indirect modifiers seem to be used without front face often nowadays. It's unclear from the catchlight of your shot though. So was the front face there?![]()
Rotalux Indirect Speedring
Discover the Rotalux Indirect Speedring by Elinchrom, designed for easy setup and indirect lighting. Elevate your photography with premium gear made for adventure!us.elinchrom.com
If you don't mind: Any compelling reason for flipping the head around even when it's hiding behind the front face?It was
The strobe is firing into the reflector. It changes the nature of the light.If you don't mind: Any compelling reason for flipping the head around even when it's hiding behind the front face?
Sconpho Spotlight 50mm CFV16 EI 100 F22 60mm by Nokton48, on Flickr+1,The strobe is firing into the reflector. It changes the nature of the light.
Canvas Background Coulmbus Camera Group by Nokton48, on Flickr
Hasselblad Anniversary 500CM CFV16 Digital Back 60mm C T Distagon 400 Strobe Macbook by Nokton48, on Flickr
Broncolor Olde Ringlight CFV16 60mm F13.5 Apus A2 6.5 by Nokton48, on Flickr
