rdeloe
I use an LCC frame with images created with the S-K APO Digitar 35/5.6 L-88. From time to time, flat field correction in Lightroom simply doesn't work. There's no obvious reason.
When this happens, I either fix the image with gradients, or run it through Raw Therapee, which works flawlessly. The problem with Raw Therapee is it makes a TIFF and I can no longer use my preferred camera matching profiles. I tried applying the profile and then exporting as DNG and as TIFF. Raw Therapee can read the DNG fine, but the adjustments are ignored, so that doesn't get me anywhere. Raw Therapee reads the TIFF with the adjustments applied without issue, but because it's no longer a RAW file, flat field correction is not available.
My guess is the flat field correction in Lightroom is just not a particularly good tool, and making it better isn't high on Adobe's list of things to do. But I thought I'd check just in case someone has a brilliant solution.
P.S. "Use Capture One" is not an answer I'm looking for.
