faneuil
Engineered for precision and stability, the Foba ASABA-R Studio Stand is the ultimate support solution for professional studio photographers working with large and medium format cameras. Towering up to 8.2 feet (2.5 meters), this robust stand features a counterbalanced central column that allows smooth, effortless height adjustments.
The horizontal arm spans 39.37 inches (1 meter) and offers dual-end mounting, enabling seamless two-camera setups. Its ball-bearing mechanism ensures precise, fluid movements for perfect positioning. A unique rotating base design—anchored by a triangular cast structure—allows the entire stand to pivot smoothly, while integrated ball-bearing castors provide mobility. A foot pedal locks the base in place, lowering it securely to the floor for rock-solid stability.
Built to support up to 13.2 pounds (6 kg) of gear, the ASABA-R stand is customizable with a range of accessories to meet your specific studio needs. Whether you're capturing product, portrait, or fine art photography, this heavyweight (211.6 lb / 96 kg) stand delivers the uncompromising support demanded by high-end studio work.
Specifications:
Specifications:
- Maximum Height: 8.2 ft / 2.5 m
- Load Capacity: 13.2 lb / 6 kg
- Arm Length: 39.37 in / 1 m
- Column Diameter: 3.5 in / 8.9 cm
- Base Type: Wheeled with pedal-activated floor lock
- Weight: 211.6 lb / 96 kg
