diggles
Price: $600
Payment method: PayPal
Shipping instructions: Free shipping to the CONUS, PayPal only, I'll pay fees.
Overall this tripod is in excellent condition and everything works smoothly as it should. There are a few marks on it from use–please see pictures:
The Manfrotto 057 Carbon Fiber Tripod with Geared Column is a heavy-duty tripod that's intended for use with video cameras and large still cameras. The tripod's geared center column provides maximum precision when you're setting the camera position. The column has a non-rotating, three-faceted design for increased system stability. You can unscrew the center-post collar, remove the center column, and attach the collar directly to the included low-angle adapter (through the chassis) to enable extremely low-angle shooting. With this method the 057 tripod can achieve a minimum height of 9.0".
Load Capacity: 44.1 lb
Max Height: 80.7"
Min Height: 9.1"
Folded Length: 26.2"
Leg Sections: 4
Weight: 8.2 lb
Leg Angle Selector: 23, 50, 75°
Low Angle Adapter
Retractable spikes in feet
Bubble level near bottom of center column
Screw locks for tightening a tripod head to the center-post collar
- there is a small ding near the head of the tripod
- each leg has scratches at the bottom from being used
- the feet are slightly worn
- the legs have slight rub marks from extending and shortening the legs, not very noticeable, but they are there
Max Height: 80.7"
Min Height: 9.1"
Leg Sections: 4
Weight: 8.2 lb
Low Angle Adapter
